      10-11-2014, 06:29 PM   #1
thecam
Italy
Drives: X3 M-sport
New code?
Hi, I have just keeped from service my X3 2.0d M.During service they have updated software of my car so all that I have coded are losts.....
No problem I have downloaded new e-sys and buyed token solution from Kristoff (Many THX Kristoff!!)
I connect the car as usual ,I code what I need ,I save ecu coded I check for see if it is aktiv and it's ok,but when I check the function on the car it isn't aktiv....for example if I code start and stop memory function and I check on cas
it is aktiv,but if I press button for shut off start and stop function and I stop the car it cames back disable,but on cas are aktiv.....does anyone have had this trouble?
Regards
Loris
