      08-10-2017, 03:01 PM   #1
csemaa
Drives: BMW X4 2015 xDrive 35i
BMW X4(F26) coding cheat sheet
I started coding my 2015 BMW X4 (F26) and the cheat sheets that I was able to get my hands on were for the F25 and F10. is there a solid F26 cheat sheet that you guys can share? thanks in advance
FSociety3812.50
      08-12-2017, 12:11 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
F010 is what you want to use. F010 and F026 use the same ECU's.
You should also be using Launcher Cheat Codes.
DBU232.50
FSociety3812.50
      08-14-2017, 04:46 PM   #3
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Really? in what sense they have the same ECU ? Just coding wise you mean.
I'm using BimmerCode app you too csemaa ?
I want to try the E-Sys way too
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      08-14-2017, 04:52 PM   #4
Almaretto
Almaretto's Avatar
2374
Main ECU's are FRM/CAS. They use the same lighting modules (TMS/LHM). They have the same head unit ECU's, etc...
Complete CAFD_ID List.
Except for NGHB, coding is the same.
FSociety3812.50
      08-22-2017, 08:11 PM   #5
csemaa
thanks, I didn't know that Esys has a cheat sheet integrated in it. I will use that for sure.
      08-22-2017, 08:18 PM   #6
Almaretto
Almaretto's Avatar
2374
Coding Made Easy
      08-22-2017, 08:20 PM   #7
csemaa
Tags
coding, f25, f26
