04-15-2013, 02:24 PM | #1 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
Dashcam: What, where, how much, etc
Anyone uses a dashcam on their F25? I'd like to get one, but I'd like it to be discreet and well integrated. I'm thinking of trying to mount it behind the mirror, but I wonder where to source the power for it...
So, anyone has one installed? Suggestions?
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
04-15-2013, 03:28 PM | #2 |
*Bimmerpost Plasti Dip Guru*
82
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
I use a dash-cam but it's a bit big like like half a iphone, I chose it because it has a screen at the back so that I could easily adjust it when it's out of focus.
If you want a dash cam that is small and discrete, I would suggest blackvue.
04-16-2013, 11:24 AM | #5 |
Rep 3
I have the Itronics ITB-100HD and it works quite well day and night. GPS is embedded into the dashcam. Not the cheapest though and it doesn't come with a screen for viewing in the car.
Here is a good site for all of the options out in the marketplace. http://dashcamtalk.com/dash-cam-comparison |
04-16-2013, 05:24 PM | #6 |
Inspector Gadget
17
Rep 202
Would anyone know how to wire a dashcam up (probably behind the rear view mirror) so as to conceal all the wires and not tie up the front 12v socket?
MY14 X3 35d M-Sport. Born 19/04/13, Delivered 31/05/13. Alpine White, Red Brown Leather, Brushed Aluminium, 19" 369 Alloys, BMW Media - Professional, Visibility Package, Access Package, Electric Seats w/ Lumbar, Variable Damper Control, Panoramic Roof, Extended Storage, HUD & Black Panel Dash, DAB, Reversing Camera & Top View, Heated Steering Wheel, Heated Rear Seats, Apps, Internet, BMW Loudspeaker Professional... & More.
04-16-2013, 06:28 PM | #7 |
Rep 3
I used the following items on my Mini Cooper to conceal the wire from rear view mirror area down to the fuse box. The wire from Metra was thinner than the original that came with my dashcam and so it was easy to tuck into the rubber strip and A pillar
- Metra Installation Kit for Most 12V Radar Detectors - Add-A-Circuit Kit for ATM fuses |
04-17-2013, 11:28 AM | #8 |
Inspector Gadget
17
Rep 202
Would doing something like this be relatively easy for someone who has very little knowledge when it comes to electronics?
04-17-2013, 01:03 PM | #9 |
Owner
132
Rep 566
I seem to have narrowed it down to a "JAEWONCNC IROAD IONE-3800FU" -- seems affordable, and the specs are OK. My nose tells me the forum of dashcam is full of FUD from people competing with each others, and their 'reports' can't be trusted...
It appears that it would be reasonably out of the view behind the mirror, on the side where the sensor isn't, and could even sit just under the "dark band" of my windscreen... Now before I buy I'll see how I can hook it up, where the fuse box is, etc...
04-17-2013, 03:18 PM | #10 | |
Rep 3
It's probably not worth messing around to save a few dollars. Perhaps the easiest way to decide is to get a quote from an auto stereo installer. For a pro it really shouldn't take more than an hour since it's just like hardwiring a portable GPS or a radar detector. |
04-19-2013, 01:15 PM | #11 |
Owner
132
Rep 566
I've tracked down a few threads mentioning how to install radar detectors, it seems reasonably trivial to hook up to the overhead lamp wires. Just need a small 12V->5V DC-DC to hide in there if needed.
I've ordered the camera, we'll see when it arrives. At the very least I'll hack it so it's a bit less visible.
04-19-2013, 01:26 PM | #12 |
Captain Unsensible
99
Rep 737
Drives: 2016 M240i Coupe - Estoril
I've got the DVR 027 720p mounted by the mirror and I run the cable up under the roof, down the A pillar, under the footwell and it plugs into the lighter.
04-19-2013, 01:57 PM | #13 | |
Inspector Gadget
17
Rep 202
04-19-2013, 02:31 PM | #14 |
Owner
132
Rep 566
I'll definitely document it.
Here's already a blob on what I use to get 5V out if 12: https://plus.google.com/111387094029...ts/hs5RpsgR4BZ With a little bit of heatshrink, it's as small as a fuse, and very efficient (no heat)
04-24-2013, 12:23 PM | #15 |
Inspector Gadget
17
Rep 202
I'll probably get one of these...
http://www.hids4u.co.uk/blackVue-wi-fi-dashcam.html It seems the way that you are meant to wire it up is run the included power magic adaptor from a couple of fuses and then tunnel the wire up the pillar. Has anyone tried to hide a wire up the pillar & along the top of the windscreen in an F25 before?
04-24-2013, 12:38 PM | #16 |
Inspector Gadget
17
Rep 202
Many of these cams have parking mode - meaning they are always on, recording and writing to buffer all the time and only copying footage to card when motion or movement is detected.
Given how complex the X3 is, would the battery be able to support one of these cameras whilst the engine is off for any extended period of time before the battery discharge device kills power to it to stop the car from not starting??
04-24-2013, 01:45 PM | #17 | |
Owner
132
Rep 566
I've seen a few posts related to hidding wires on the F25, mostly for people installing radar detectors... I've even seen a guy routing it all back to... the trunk fuse box, for some bizarre reason Quite frankly I quite prefer hooking into the ceiling electrics...
04-24-2013, 01:49 PM | #18 | |
Owner
132
Rep 566
I hope the camera parking mode uses less power, thats why I plan to use a clean DC-DC switcher to 5V, and possibly mod the camera itself if it uses a lossy linear regulator. It's main rail is probably 3.3 anyway. I will hook it to my bench power supply and run tests in it before it even approaches the car :-)
04-24-2013, 03:28 PM | #19 |
Rep 2,527
Precisely due to this concern, some have come out with battery packs for dashcams. I surmise you could charge it while the car is running, or when you're home. Like an uninterruptible backup power system
04-24-2013, 04:08 PM | #20 | |
Rep 614
04-24-2013, 04:20 PM | #21 | |
Inspector Gadget
17
Rep 202
Are there any good quality alternatives that have GPS, WiFi & Parking mode?
