10-17-2012, 07:39 AM | #1 |
Rep 144
heated rear seats - can they be retrofitted?
Hi All
I have heated front seats, does anyone know if the heated rear seats can be retrofitted. I have a 2012 f25 2.0d SE. I should imagine this is no more than a heated seat element per side and two switches that I assume sit in the arm rest housing (facing the rear seats). It sounds like it should be easy, but.... |
10-17-2012, 09:42 AM | #4 |
Rep 144
http://realoem.com/bmw/showparts.do?...g=65&lang=enUS
OK found this and these parts...not sure if this is all that is needed, no idea of costs involved or how on earth the seats would be seperated to accomodate the heating elements etc...Its probably not something I can do. No. Description Supplement Qty From Up To Part Number Price Notes Photo 01 Heater element seat 2 52207235762 02 Heater element backrest 2 52207235763 09 Switch, seat heater, left rear 1 61319163292 09 Switch, seat heater, right rear 1 61319163293 10 Plug, see part information in 'ZI' colum 2 61133333333 $12.24 |
10-17-2012, 12:38 PM | #6 |
08 X3 6spd
28
Rep 112
I know some manufactures actually install the heating elements in all seats but not the switch in the cars without the heated option. All you have to do is install the switch and you're golden. Wish that was the case here!
10-17-2012, 12:47 PM | #7 | |
Rep 144
What am I saying its a BMW ***slaps heads*** |
10-17-2012, 01:52 PM | #8 |
Rep 469
Doesn't the RealOem site you quoted earlier on show you the standard parts, and the optional parts (for heated seats). Wonder if there is a part code for heated or non heated- I doubt it otherwise there would be too many variations i.e. Standard with/without, Sports with/without, Electric with/without.
10-17-2012, 02:20 PM | #9 |
Rep 144
Yes it shows the seats there is no mention of any integrated heating element as standard. The heated components are separate.
Wonder how much a dealer would take. Too much probably. |
10-17-2012, 02:29 PM | #10 |
Rep 38
I looked here
http://parts.bmwofsouthatlanta.com/default.aspx All I could find were rear seat switches. It looks as if all seats are the same besides the leather color and leatherette. So best bet would be to look where the switches would be for rear heating and check for cables. If no cables then find out from someone with rear heated seats where the cable is coming from. There should only be one cable in the rear seats for heat since these are not powered. |
10-17-2012, 02:30 PM | #11 |
Rep 1,511
I'd be interested too.
Up here heated rear seats was a $3000 option. OK, officially it was a $500 option but leather was also required which I didn't want. I expect the seating surface is glued to the seat padding which would make a retrofit someone of a pain in the arse.
03-22-2013, 10:04 AM | #13 |
Rep 166
Hate to bring a thread back from the dead, but anyone have any updates on this?
2016 BMW X3 35i X-Line, 2014 BMW X5 35i Luxury Line
Retired: 2013 BMW 335xi M sport, 2013 BMW X3 28i, 2006 BMW 325xi, 2008 Infiniti G37S, 2008 Infiniti EX35 |
03-23-2013, 10:42 AM | #16 |
Rep 321
Adding rear-heated seats is likely to be complicated and expensive.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list. |
03-23-2013, 04:04 PM | #17 |
Rep 1,511
Nation Geographic's Megafactories has an episode of the x3 production. There was a segment on the seat production and specific seats are made for each order. It's unlikely the electrical for the rear seat heaters is in place... too much bloody work.
03-26-2013, 10:39 PM | #18 |
Rep 166
My understanding is if certain options are selected, certain options are pre-wired to minimize the different wiring harnesses required (though this could be wrong). Intuitively I would imagine if heated front seats/Cold Weather Package were selected then heated rear seats/Cold Weather Package II could be pre-wired - I haven't pulled the rear seats up to check for a wiring harness, but maybe somebody has? According to realOEM.com the components are available separately:
Seat heaters - http://www.realoem.com/bmw/showparts...31&hg=52&fg=65 Trim pieces - http://www.realoem.com/bmw/showparts...96&hg=51&fg=35 Switches - http://www.realoem.com/bmw/showparts...01&hg=61&fg=35 If the harness is pre-wired, this actually doesn't look that complicated or expensive. I'll continue to dig...
Retired: 2013 BMW 335xi M sport, 2013 BMW X3 28i, 2006 BMW 325xi, 2008 Infiniti G37S, 2008 Infiniti EX35 Last edited by qwertyb22; 03-26-2013 at 10:48 PM.. |
03-31-2013, 06:56 AM | #20 |
Rep 166
Waiting to hear back from one of my dealer's service guys. The sales manager, a friend of mine, says it looks like it can be done with the parts I listed above but is waiting to confirm with someone who has taken the back seats apart before. I'm optimistic that it should be possible and reasonably priced, but I'm making the assumption this will be for cars with heated front seats rather than all-comers.
03-31-2013, 08:50 AM | #21 |
Rep 166
Unless I'm mistaken, the pre-wiring would just be the harness. The heater elements are a separate part number and would have to be installed under the seat covers. I don't think there is any other wiring for the seats. My wife has the car and is away for the weekend so I can't check it out right now. Does anyone with heated front seats want to check under their back seats for a wiring harness?
03-31-2013, 01:01 PM | #22 |
Nuclear Chief of the Watch
120
Rep 637
The wiring harness are made to suit the options selected for each vehicle so if you did not order them the cabling wont be there.
Ebay appear to have several Non-OEM options which would be less $100 if you can get under your seats.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
