09-02-2018, 02:43 PM | #1 |
Rep 290
Slight miss at idle
I have a slight idle miss on start up. If I just bleep the throttle it will clear out. New plugs, air filter oil change and VANOS solenoid cleaning recently. Any ideas are welcome.
09-03-2018, 08:49 PM | #2 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
Check the MAF. Likely is just dirty or has worn out. Also, make sure you have the correct oil in, could be the cause during cold starts.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
09-04-2018, 07:39 AM | #3 |
Rep 741
are you tuned? did you install spark plugs with a shorter gap? if so, this is common.
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
09-04-2018, 05:32 PM | #4 |
Rep 290
09-04-2018, 05:33 PM | #5 |
Rep 290
09-05-2018, 08:07 AM | #6 |
Rep 540
Yep let us know if it works
Good luck!
09-07-2018, 09:28 AM | #8 |
Rep 540
Is the issue fully resolved? if it still persists a little, I would recommend giving all other sensors a good cleaning.
