      10-20-2018, 03:53 PM   #1
seattleweather
Drives: 2014 X3
2014 X3 oil capacity
What's the oil capacity for 2014 X3? 6 qt or 7 qt?
Thanks.
      10-20-2018, 04:12 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
6 cyl motor: 7 quarts
4 cyl motor: I believe it's tad bit over 5 qts.
      10-20-2018, 04:34 PM   #3
seattleweather
Drives: 2014 X3
So 2014 X3 Xdrive28I should be slightly over 5 qts?
      10-20-2018, 04:42 PM   #4
Wgosma
Yes. you might double check w/Google search. (I don't think this info is in the owners manual but maybe; it's not listed in the manual for my car w/6 cyl. motor)
4 cyl. (28i) is the N20 model engine - I found capacity is 5 liters or 5.3 Qts.
________4158.50
      10-20-2018, 04:46 PM   #5
________
________
4159
Drives: ________
4 cyliner (28i) is the N20 model engine - I found capacity is 5 liters or 5.3 Qts.
This is correct.
28i (2.0) = 5.3 quarts or 5 litres
35i (3.0) = 7 quarts or 6.5 litres
Older model 2011 N52 28i (3.0) is also 7 quarts.
      10-20-2018, 06:02 PM   #6
seattleweather
Drives: 2014 X3
Thanks for the info. I almost poured 7 qts.
________4158.50
      10-20-2018, 06:43 PM   #7
________
________
4159
Drives: ________
      10-20-2018, 07:44 PM   #8
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
Or...check the manual
      10-20-2018, 08:25 PM   #9
________
________
4159
Drives: ________
The manual will say what has already been said.
      10-20-2018, 08:28 PM   #10
BMWZ4
BMWZ4's Avatar
1910
Yes of course. I meant, checking the manual before posting the question
      10-21-2018, 10:26 AM   #11
Opie55
Drives: '15 650i Convertible
It's not in the manual. BMW doesn't want you to know that stuff, apparently because they want you to have the dealer do everything. And if you do a basic google search, you will get a variety of answers.
      10-21-2018, 10:28 AM   #12
BMWZ4
BMWZ4's Avatar
1910
Odd, it's in mine
      10-21-2018, 03:58 PM   #13
________
________
4159
Drives: ________
Mine does not have it either.
Looked on page 245 (engine oil) and 270/271 (technical data/capacities)
Odd, it's in mine
Interesting. Which page?
