      10-15-2018, 12:25 PM   #1
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Air rushing noise from catless downpipe
I installed the VRSF downpipe a few weeks ago and have heard this high pitch air rushing sound since I have installed it. I've listened to videos of other N55s with the same set up (Catless DP & stock cat back) and they do not make the same noise at all. I have replaced the turbo gasket and the Vband clamps are next. What baffles me is that this sound only persists for about 10-20 seconds until the engine revs down from the cold start. It also makes a pretty horrible 'turbo spool' noise while driving under light to medium throttle only in Comfort Mode (may be tune related) then again, I have heard no other N55s make.
Looking for any suggestions/Advice
Video link:
My apologies, I am not sure why the video looks like I recorded it on an Ipod Shuffle
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      10-15-2018, 05:51 PM   #2
doodlebro
Drives: '17 X3 35i
On cold start, the wastegate pops open to heat the cat faster. I think you're just hearing that... Shouldn't be any great concern as long as it doesn't get worse/happen at other times.
You can turn cat heating off with bootmod3, but I leave it on cause it sounds great!
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      10-15-2018, 05:53 PM   #3
TheCoolX3
I experimented with turning it off and it just sounds dumb. Any thoughts on why this is happening to my x3 and not others with the same mods?
      10-15-2018, 05:58 PM   #4
doodlebro
Drives: '17 X3 35i
I think the other drivers are turning cat heating off.
In a couple of weeks I'm installing my VRSF catless, so I will be able to confirm this.
But I do think it's normal/expected if you just hear it until it revs down. Basically, the car optimizes flow through the cats during startup to get them warmed up quicker. It's an efficiency thing. I think you're just hearing the lack of back-pressure from the primary cats, since you've removed them.
Current mods
      10-15-2018, 06:28 PM   #5
E90705
E90705's Avatar
Drives: E90/F25 M-sport
Have you tried/experimented with cold start delete?
      10-21-2018, 07:41 PM   #6
TheCoolX3
I believe this sound to be the infamous waste gate rattle that N55 PWGs suffer from. However it does not sound like a rattle or clicking but an air rushing noise.
Was gonna try using heat wrap to quite or kill the sound - Will post back with results.
Will also play with cold start delete.
Any other suggestions?
      10-23-2018, 01:27 PM   #7
rcsup1
Drives: x3 35i
Sounds like waste gate rattle from the cold start. Do the cold start delete. My car makes this sound, though not as loud, since I still have my cat still
installed.
      10-23-2018, 02:40 PM   #8
Victoracer
Victoracer's Avatar
Drives: F25 X3 xdrive35i M-Sport FBO
I am fbo and have the vrsf race cat which sounds just like this. I don’t think there is an issue personally. But videos never do justice when trying to diagnose sounds. GL
