      10-15-2013, 08:11 PM   #1
iastategolfer
Drives: BMW X3
2012 BMW X3 xdrive28i
Hoping for some suggestions, knowledge, etc
I have a 2012 BMW X3 xdrive28i and I can connect just fine to bluetooth phone. I recently drove an 2013 X5 and was able to connect both bluetooth phone and audio. I cannot seem to find the audio option on my X3 so after some research looks like I need to upgrade something...
Any ideas on what needs the upgrade? Estimate on cost?
Thanks in advance from a newbie!
Cheers,
Brad
      10-15-2013, 10:24 PM   #2
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
Cheers,
Brad
Make sure that you haven't plugged a USB cable into your iPhone before pairing the phone as both a telephone and an audio source. iDrive will not let you have both at the same time.
      10-16-2013, 06:20 AM   #3
nyalpine90
nyalpine90's Avatar
7422
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
i have the same problem, i can bluetooth only phone but no audio. if i want to play music i have to plug the aux.( for pandora)
i think you need the tech. package
      10-16-2013, 10:44 AM   #4
nonagon
nonagon's Avatar
Drives: Porsche Cayenne GTS
You need to make sure Bluetooth audio is enabled on your device. Go to CD/Multimedia > Bluetooth > Highlight your phone and click the Option button (bottom right under the iDrive wheel). Select Configure Phone from the Options panel on the right and check the audio option. You can also check in Options to see if Bluetooth audio is disabled for all devices under Configure Bluetooth. Like someone mentioned, hooking up a USB cable will disable bluetooth audio for that device and it needs to be manually re-enabled after that. Sound quality over Bluetooth is noticeably better than via USB, for some reason, in our X3s.
      10-16-2013, 11:22 AM   #5
boostified
Drives: 2013 X3 35i M Sport
it also depends on the software of your BMW. Our 2011 X3 35i didn't have that function. We were able to use bluetooth for phone calls, but not for audio. We now have a 2013 X3 and made sure that feature was with the car when we bought it. =) You might be able to get that added to your car since I think its a software thing.
      10-16-2013, 12:10 PM   #6
nyalpine90
nyalpine90's Avatar
7422
2016 BMW X4  [9.33]
i still think its technology package. i dont have bluetooth for audio just phone
      10-16-2013, 12:28 PM   #7
boostified
That makes sense. Does the OP have the technology package?
      10-17-2013, 09:20 AM   #8
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
http://www.f30post.com/forums/showthread.php?t=691724
to quote:
6NH - bluetooth phone
6NK/6NL - Bluetooth AD2P (extended audio functions), voice control, album art, multiple lines
      10-17-2013, 10:17 AM   #9
nyalpine90
nyalpine90's Avatar
7422
2016 BMW X4  [9.33]
my gf x3 '14 was in for minor rattle on driver window and bubble on front grille chrome part.
she has a x5 '13 , we were able to bluetooth phone for audio and "media" allow to control pandora with x5 controls no need to touch the phone.
when i switch back to my x3, i was only able/given the choice to connect audio only.
      10-18-2013, 08:55 AM   #10
iastategolfer
Drives: BMW X3
does anyone know if the software can be updated? is the tech package available for purchase?
      10-18-2013, 12:27 PM   #11
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
You can try updating the bluetooth software of the car
      10-25-2013, 10:13 AM   #12
saulgoodman
saulgoodman's Avatar
Drives: 2012 F25 N52T
2015 BMW 328XI  [0.00]
for 2012 model year there was a $650 mandatory option called "BMW Assist with Enhanced Bluetooth and office capabilities"...this is in addition to the standard bluetooth/USB functionality. This option was free with tech pkg and it's required play Bluetooth audio.
Default firmware shipped with the car didn't play BT audio from my iPhone 4S but worked with my Xperia Arc. After upgrading the firmware, things were resolved.
