      10-20-2013, 11:48 PM   #1
ioschi2003
Drives: BMW X3 3.0
Question ECO PRO Function X3 F25 3.0D *** HELP ***
I coded Manually the ECO PRO Function on my X3 F25 3.0D
as follow but is not possibile to flag some options ( see the pictures )
HU_CIC > 3000 HMI > ECOMODE >Aktive
HU_CIC > 3000 HMI >HVAC_MSD_EFFICIENCY >Aktive
HU_CIC > 3000 HMI >EFF_DYN_SYS_CID >Aktive
HU_CIC > 3000 HMI > ECO_FDS_POPUP>Aktive
HU_CIC > 3000 HMI > ECO_MODE_CONF>Aktive
HU_CIC > 3000 HMI > ECO_ROUTE>Aktive
HU_CIC > 3000 HMI > ECO_TIPPS>Aktive
KOMBI > 3003 FZG >VERBR_HISTORIE_ENABLE>Aktive
KOMBI > 3004 ERM > CTR_HSTY_DISP_KI_APPL >Aktive
IHKA > 3000 > ECO_PRO_MODE >aktiv
ICM ECU: 3000 -> IcmKod_B_ECONOMIC > verbaut
Probably the problem is here:
3003 ECO_FDS, 3C FDS_MENU_TEXT"n" & FDS_MENU_SIGNAL"n" where is possible to define the different menu
my Actually menu is NORMAL, SPORT , SPORT+ , without ECO-PRO
Anybody in the forum has X3 F25 with ECO PRO function from the factory and can check the right parameter ?
thanks in advance
      12-29-2013, 07:07 AM   #2
thecam
Italy
Drives: X3 M-sport
uppppp noone could help????
