12-05-2011, 04:50 PM | #2 | |
Rep 1,041
If I HAD to remove one without risking damage to the muffler/tailpipes, I'd probably split it lengthwise with a cut-off wheel, and then pry it off. |
12-05-2011, 05:01 PM | #4 | |
Rep 1,041
BMW does make a polished pipe tip specifically for your 20d. It does not require any welding to install. Part No. 18308511364. |
12-05-2011, 05:40 PM | #5 |
Rep 764
They take moderate to easy force to install. I used the palm of my hand. If you can get behind the pipe you may be able to bend the two tabs forward. The tabs and their position are the only thing holding it.
12-06-2011, 01:57 AM | #6 |
Rep 1,041
The force to install them must vary a lot (possibly tolerance of the tab angle and the tailpipe diameter). I helped a friend put a pair on a 2011 28i (Bronze Metallic w/Sand interior and no rust on the pipes) last August and it finally took wrapping the tips in a towel and firmly tapping on them with a rubber mallet. There was no way that the two of us could slide them on with "moderate to easy force", or even excessive force and a lot of swearing. Both his and mine are going to remain in place until the mufflers are replaced.
12-06-2011, 11:38 AM | #7 | |
Rep 764
12-06-2011, 02:59 PM | #8 | |
F25 X3 2.0 Diesel
Rep 48
Drives: 2012 BMW x3 20d 8SpdAUTO BLACK
12-06-2011, 04:14 PM | #9 | |
Rep 1,041
Don't know if 3A Racing delivers to Hounduras, but they make one that's easy to install (includes an internal mounting bracket/clamp), will fit the 20d and is even larger than the BMW oval tip. Costs less then $10 US. They also make a "regular-sized" one, if you think that size doesn't matter. |
12-06-2011, 05:47 PM | #10 |
Rep 82
12-06-2011, 10:08 PM | #11 |
Rep 41
I'm trying to remove my current chrome BMW one so I can get it powder coated gloss black.
