      03-25-2017, 02:16 PM   #1
alpwhite46
Drives: 2013 X3 35i Mpkg
H&R vs Eibach Drop
I haven't been able to find many people with the Eibach's on the X3 except for one guy on the forum, looks like H&R is more pre-dominent.
Strange thing is, the drop on the Eibachs looks quite big in the photos compared to the specs:
Any feed back?
According to the site
Eibach:
Front drop: 1.0 in.
Rear drop: 0.5 in.
H&R:
Front drop: 1.4 in.
Rear drop: 1.3 in.
Comparison white x3 with H&R
Eibach:
FSociety3812.50
      03-31-2017, 12:32 PM   #2
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Maybe I was that one guy
Eibach firms up the ride quite nicely and is very well controlled, but the X3 still rolls a bit on turns. I used what's marketed as X3 35i springs on my X3 N20, but the drop is smaller than I'd like. It's not going to look like a baby X5 M Sport.
      03-31-2017, 01:17 PM   #3
Tjalle
Drives: X4 35i
Sorry guys - you asked for it - this is the real deal. I am very satisfied with improvement in handling, but there is somewhat harsh ride. H&R.
      03-31-2017, 03:46 PM   #4
alpwhite46
Thanks! Well i have 19's, not 20's so it should help with the harshness no?
      04-01-2017, 12:44 AM   #5
Tjalle
Drives: X4 35i
Yes a bit, but RFT is a problem - go for non-RFT:s when new tyres. Add 12V compressor and sealant/slime. Amazon.
Also I am riding close to bump stops - not shortened shocks - so at bumps there is an earlier contact with stops. Stops are soft and will compress about 50mm.
      04-01-2017, 08:42 AM   #6
alpwhite46
Yeah i just got the Pirelli Pzero nero , non RFT.
      04-03-2017, 09:39 AM   #7
pokerface
pokerface's Avatar
sorry for the bad quality - boosted the brightness so you can see the gap.
      04-05-2017, 02:09 PM   #8
Lotus99
Lotus99's Avatar
Drives: 19 M2C & 18 X3 M40i
Here's all my research on the 4 brands of springs I found, plus coilovers I was considering at the time. IIRC, Eibach has different springs for Europe vs. NA. The drop is greater in Europe.
Super happy with my H&R's. You can search up my posts For more details.
      04-06-2017, 02:10 PM   #9
NightM
NightM's Avatar
450
Drives: Bmw
Dry fitted my old wheels next stop KW's. If they make it
      04-06-2017, 02:11 PM   #10
NightM
NightM's Avatar
450
Drives: Bmw
20" maybe a thicker tire also
      04-06-2017, 03:53 PM   #11
Lotus99
Lotus99's Avatar
What do you mean if they make it? If KW still makes coilovers for the X3? I'd be surprised if they've stopped. As of a year ago, As I indicated in my document above, the KW V2's were Available, as were a few other options for our car.
If you do get the KW's, or any other coilover for the X3, you would be the first I have heard of on this forum!
      04-06-2017, 03:59 PM   #12
NightM
NightM's Avatar
450
Drives: Bmw
Good! Ill
Lookinto it. Im done building my M5 so my girls car is next. Just put on rims for now so now gotta get kw's then. And make some power.
Tnx
      04-07-2017, 01:15 PM   #13
alpwhite46
Thanks! i found them for 420 including tax here in Toronto - cheapest so far!
I'm surprised the rear drop for you is only 0.98"
      04-07-2017, 04:05 PM   #14
Lotus99
Lotus99's Avatar
Yeah, me too. It might be because I already had the OEM Sport suspension (option code 226) on my car before, which is really rare. It comes with different springs, shocks and sway bars from the factory, and I suspect those springs are already lowered a bit compared to the regular ones that come with option 225.
Regardless, now the gap in the front is slightly less than the rear (8 mm), which is the perfect look, and is almost even front to back.
Would definitely recommend you add spacers afterwards, as it completes the look. I went with 12's up front and 20 in the rear.
      04-07-2017, 04:45 PM   #15
alpwhite46
Noted thanks - will see what to run with my wheels when i lower it!
