      09-15-2020, 10:52 AM   #1
BMWfan73
Lord of Glencoe
BMWfan73's Avatar
Drives: '15 xDrive35i M-Sport
35i Eco Mode
How much of an improvement can I expect (roughly) to see from making a long highway miles only drive (several hundred) cruising in eco-mode compared to normal? Trying to calculate fuel stops/pricing prior to the upcoming trip. Does eco on the highway make that much of a difference?
      09-15-2020, 02:43 PM   #2
S4NoMore
S4NoMore's Avatar
Drives: 16 340i, 15 X3d, 91 318i
2016 BMW 340i  [0.00]
2015 BMW X3 28d  [0.00]
1991 BMW 318i  [8.66]
If you use cruise control it will likely dull the amount of acceleration as you go up and down hills, which would help. It will also run the engine a few degrees hotter which reduces frictional losses. If you don't use cruise control, it allows "sailing" (basically trans disconnects engine from drivetrain, rpms drop to idle) to coast down hills for a longer distance before you need to throttle up to continue at speed. But realistically it's probably less than 10% improvement overall.
      09-15-2020, 03:12 PM   #3
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
eco mode is most effective in city driving
      09-15-2020, 03:14 PM   #4
najnad
najnad's Avatar
to conserve fuel on mostly highway driving, just drive the speed limit and make sure your tires are properly inflated, maybe a few pounds extra
      09-16-2020, 12:09 PM   #5
BMWfan73
Lord of Glencoe
BMWfan73's Avatar
Thanks for the replies. I don't use (I actually really dislike it) cruise control.
      09-18-2020, 10:17 AM   #6
Aspen235
Drives: 2014 X3 35i, 2018 M240i 6mt
Cruise control will improve your FE more than eco mode, I would think.
      09-18-2020, 11:14 AM   #7
S4NoMore
S4NoMore's Avatar
Cruise control will maintain speed within some parameter, and where that causes FE to suffer is on slopes. Put simply you're best to slow down as you climb a hill, and then coast down it, at speeds beyond the parameters of cruise. BMW even labels this as a feature - "cruise control with brake" because the car will apply brakes to slow you down rather than coasting. Braking = wasted energy. This is where the "sailing" function comes in.
      09-21-2020, 01:59 AM   #8
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
I used it over a 300km highway trip, cruise set at 120km/h. Saved maybe 5km over the entire trip. Even in the city I find it's next to useless unless you really play the long game. I save maybe 15km / 750km tank.
I just keep it in comfort now, unless having fun in sport.
It does have advantages if you're trying to keep RPM low while the engines reaching temp but that's all it's good for in practice IMO
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      09-21-2020, 03:41 PM   #9
BMWfan73
Lord of Glencoe
BMWfan73's Avatar
Thanks, sounds like it's not a lot of savings for the short-term.
(OO)=[][]=(OO)
      09-21-2020, 07:55 PM   #10
scostu
scostu's Avatar
Drives: 2016 F25
Whats ECOmode?
      09-22-2020, 07:40 PM   #11
najnad
najnad's Avatar
Originally Posted by scostu View Post
Whats ECOmode?
Mine is a 2011...there is no Eco mode in those F25s...
      09-29-2020, 08:16 PM   #12
Aspen235
sure, but on flatter ground cruise control beats manual throttle. I think cruise vs manual is a greater saving than eco vs standard.
