      07-15-2015, 11:48 AM   #1
Tangsta
Drives: '22 x3 M40i
Brake issue in hot weather
During a heat spell in the last week of June (the temperature was above 30*C / 86*F) my brake pedal started to sink under constant pressure and need to be depressed further and further to maintain the same braking force.
A few times at a stop, I'd be holding the brake pedal constantly and the car would start rolling forward again until I pressed the brakes further, all the way until it was about 1 inch off the floor.
I haven't read about any issues like this concerning F25s, but all other forums seem to point to a faulty master cylinder.
I took the car in to the shop a couple days ago, but with it being a relatively cool day, they weren't able to replicate the issue and the diagnostics ended there (after also checking for fault codes).
There's a lot of you in much warmer climates than here in Calgary... Anyone else experienced this issue? I feel like the dealership could/should have been more proactive, but I'm a bit at a loss as to what else they could do. Thoughts?
      07-15-2015, 12:19 PM   #2
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
No problems here in inland So. California.
Last time you had a brake bleed....brake fluid is hydrophilic.
Somewhere off the internet...."Because brake fluid is well known as a hygroscopic fluid, its molecular O-H structure easily allows hydrogen bonding with hydromolecules, e.g., H2O. The moist brake fluid reduces the boiling point and moreover causes the deterioration of the functionality of the brake system."
      07-15-2015, 12:28 PM   #3
ChicagoNorthShore
ChicagoNorthShore's Avatar
Drives: 2020 BMW X3 M
2020 BMW X3 M  [0.00]
It was just 90 degrees here in Chicago and I drove the car around all day and had absolutely no problems, must be your car.
