      09-06-2020, 02:08 PM   #1
DVMs135
DVMs135
DVMs135's Avatar
Drives: 2018M240i, 2016X3 35i and a 20
Wheel compatability 2011 to 2016 F25
I have just traded in my 2011 X3 35i for a low mileage 2016 X3 35i, in showroom condition. I have a set of Blizzak non RFT snows on OEM 2011 rims that I intend to use on my 2016. Question for the wheel gurus here, will those OEM 2011 rims fit my 2016?
`The Lust for Thrust'
      09-06-2020, 06:28 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
typically with BMW the wheel "offset" within a given Model series (F25 in this case) will be the same regardless of model year, so your older wheels will fit. You can double check by looking up wheel specs at either RealOEM or NewTis.info website.
DVMs13518.00
      09-07-2020, 08:14 AM   #3
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
Since they are both F25, they'll fit with the following caveat. Some of the sport models require bigger wheels to clear bigger brakes. For the F25, I believe any 18" wheel or larger will clear brakes on all models. So the only thing you might need to consider is if the wheels are 17" and you have upgraded brakes.
Wgosma806.00
DVMs13518.00
      09-07-2020, 11:19 AM   #4
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
This is correct.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
DVMs13518.00
      09-07-2020, 12:50 PM   #5
DVMs135
DVMs135
DVMs135's Avatar
This is correct.
Thanks for the responses.
      09-07-2020, 03:32 PM   #6
Nikful
Drives: 2017 BMW X3 XDrive 28i
I am running 2015 X1 17" wheels on our 2017 X3 in place of the original 19's and they fit perfectly.
