06-08-2022, 11:26 AM | #1 |
Rep 37
Intercooler for F25 N20?
I've got the FTP Motorsport boost/charge pipe kit, so while I was in there I figured I'd swap the intercooler as well.
VRSF makes this one: https://www.vr-speed.com/vrsf-5-stre...5-f26-n55.html But it says it's only compatible with the N55. Is that actually true, or will it fit the N20 as well? The alternative is the one ARM makes: https://www.armmotorsports.com/colle...tercooler-fmic ARM says it's compatible with both, which is why I'm curious if the VRSF one will actually fit the N20. Or is the reason the ARM will work with both is because it's got those flexible silicone hoses and the boost/charge pipes for the N20 are in a different spot than the N55? Or should I look at another FMIC? The options seem pretty limited. |
