07-17-2013, 12:45 AM | #1 |
The Ultimate Driving Machine
35
Rep 92
Eco Pro
can someone explain me what is the Eco Pro????? it feels different but what about the batery charging...
sorry but i simply dont get it ... thanks |
07-17-2013, 02:21 AM | #2 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
changes the engine map so the turbo(s) kicks in later, adds a bit of latency to the first part of the accelerator curve, lower the response curve of the AC, and turn down the output of the heated mirrors.
The idea if that if you drive calmly, you have quite a bit more 'goo' under the foot, and thus save a lot of fuel... There must be a few more tweaks of course...
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
07-17-2013, 06:27 AM | #3 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Just imagine Eco Pro is like a condom
07-17-2013, 09:32 AM | #4 |
Rep 5,447
Just turn it on when you want to know what it is like to own a Prius, then turn it back off cause it sucks!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-17-2013, 09:49 AM | #5 |
Rep 66
It's a bit like driving with a brick under the accelerator pedal, also gives a nasty throttle lag when you want some quick acceleration. Can be useful in certain driving situations if you are driving at a constant speed on motorway or fast road or in slow moving traffic. Saves a bit of fuel which is a good thing with UK fuel prices!
Pity that the switch for the control is on the centre console as you have to take your hand off the wheel to change it to comfort/sport, would be better on steering wheel. Other approach on automatic is to knock the gear lever into sport mode if you need quick acceleration. |
07-17-2013, 03:12 PM | #6 |
Rep 15,858
Remember we still have the same engine output in EcoPro, if we give it full throttle.
I was driving an F30 320d EfficientDynamics the other week for 3 days and tried all the modes and it felt just as fast in EcoPro, once you ignore the extended/different throttle characteristic. EcoPro is partly designed to encourage a smooth and therefore more economical driving style. HighlandPete |
07-17-2013, 03:47 PM | #7 |
Owner
132
Rep 566
In fact, I find I get more "pull" out of Eco pro than in sport mode(!) for say 0 to 60. Just floor it. Same when taking over another car, drop /2/ gears and floor it, and the engine is definitely not lagging then!
The 'lag' is only on the first part of the accelerator curve, when driving 'gently'.
07-17-2013, 06:29 PM | #8 |
Rep 1,511
I don't mind eco pro... just press the go pedal a little harder and the car accelerates OK. Press the pedal quickly and the car scoots.
I like the short shifting nature of eco pro too since the the engine has enough torque to pull well even when short shifting.
07-17-2013, 07:08 PM | #9 |
Rep 1,450
I use Eco Pro only when I'm cruising on freeways. I find it weak that's why I'm using comfort most of time & sport on DS mode whenver I needed power when merging or overtaking.
07-18-2013, 12:24 AM | #10 |
Rep 480
Eco Pro turns a 35i into a 28i
2016 BMW X5 ///M 2016 BMW M4 ///M Convertible aLatteHotte - www.aLatteHotte.com - The Future of Coffee |
07-18-2013, 02:36 PM | #11 |
Pshhhhhh
10
Rep 159
To the gent who said Eco Pro is like driving a Prius... I have a Honda Insight as our daily commuter and I can tell you that Eco Pro is 100 TIMES better than an Insight LOL
2014 BMW X3 xDrive35i M-Sport
Alpine White w/ Black Nevada/Brushed Aluminum |
07-26-2013, 05:19 AM | #12 |
Rep 50
I was sceptical about the eco pro, but i find myself using it often when driving in my neighborhood in speeds of 30 to 50 kmh, due to the fact it runs lower on gears and dont gear down as often as when not in ecp pro. I like that, maby because i have the 2.0D.
Other engines may behave differently for what i know.
MY14 X3 2.0D Deep Sea Blue M-Sport, Oyster colored cow, allOpt.
07-26-2013, 09:10 AM | #13 | |
81
Rep 1,174
