06-03-2013, 09:33 PM | #1 |
Rep 102
Golf tee mod really do anything
I did the mod by unclipping the connection in the trunk and I really cant hear any difference at all. I did notice the right tail pipe getting black. Is it that minor or is this not working?
06-04-2013, 08:07 AM | #2 |
Rep 5,445
If it is working, both tailpipes should be getting a bit black instead of just one. On my 08 335i it worked, but on my 2011 X5, they changed how it worked so that unplugging would keep the valve closed all the time instead of open all the time like my 335.
Wondering if the X3 is the same as the X5 or the 335 - best to just start it and hold your hand behind each tailpipe and see if you get flow out of both - if the valve is open, they both should flow evenly at low RPM like idle, at higher RPM it should be open either way.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-04-2013, 01:30 PM | #4 |
Rep 323
The easiest way to do this is to unclip the little compartment on the inside left of the tailgate and you'll see a bunch of wires and such for the amp, etc. There's a little solenoid valve that you can unplug and just leave unplugged, and this will leave the flap open all the time. When you get sick of it, it's super simple to just plug it back in and the flap goes back to normal. Doesn't throw any codes or cause any problems, and the exhaust does definitely get a bit louder.
06-04-2013, 02:38 PM | #5 | |
Rep 5,445
The older cars used to use vacuum to hold it close, now they use vacuum to hold the flap open, so thinking that anyway you do it, it may just be closed and you will have to take a zip tie and put it around the external actuator arm and prop it open. That is how the X5 has been for the last 3 years.
06-04-2013, 06:17 PM | #8 |
Rep 5,445
It didn't on my X5, seems it is var enough away on the actuator arm not to get that hot, but sounds like the plug inside is the better way to do it these days!
06-04-2013, 07:21 PM | #9 | |
Starfleet Command
315
Rep 785
Can you take a pic of this solenoid valve and plug? I looked and see alot of clips. thanks SCott
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels, |
06-05-2013, 08:30 AM | #10 |
Rep 102
There is only one. Pull down the piece with the net on the driver side near the tailgate and really the only thing in there is a clip that has a vac line attached. Just push the metal retaining clip and unplug.
06-05-2013, 09:16 AM | #11 |
Starfleet Command
315
Rep 785
I see 3 potential clip to pull... can someone specifically point out the correct for me.
22" 747M wheels, |
06-05-2013, 10:16 AM | #13 | |
Starfleet Command
315
Rep 785
I see the 2 rubber vac lines connected...what exactly should i disconnect? The tubes? there is a metal clip but it seems attached to something above the vac lines with 2 other electrical wires running up and away. Can someone please make this crystal clear for me.
22" 747M wheels, |
06-05-2013, 11:05 AM | #15 |
Starfleet Command
315
Rep 785
Thanks got it!!
I unclipped it. Doesn't sound any diff to me. will drive it today.
22" 747M wheels, |
06-05-2013, 11:26 AM | #17 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Remember, this does throw a shadow code when the dealer checks it.
06-06-2013, 01:37 AM | #20 |
Rep 323
I've taken mine to the dealer quite a few times with it unclipped, never heard about it and it's still unplugged. Don't think it's a big deal.
06-14-2013, 06:40 AM | #21 |
Rep 292
+1 Did it for a while and plugged it back in.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
06-14-2013, 07:10 AM | #22 | |
81
Rep 1,174
Especially if the flaps inside becomes permanently open.
