12-05-2014, 09:37 AM | #1 |
Rep 66
Windshield wiper annoyance
Ok maybe I'm missing something, but it seems like my windshield wipers only go SUPER FAST or slow.
I have a 2014 28i X3 with several packages. My options seem to be: 1) Automatic wiping button - too slow and collects a lot of water on the windshield before wiping 2) Pressing the wiper handle UP once (not a hard UP) and getting too fast. The scroll button on the wiping handle (which I think is supposed to control the speed?) is set to the lowest setting (all the way down) but I tested it this morning and moving the setting did not adjust the wipers at all. Is it possible my scroll button just doesn't work and my wipers can only go fast? |
12-05-2014, 09:56 AM | #2 |
Rep 2,531
I've never had that problem on our 2011, 2012, or 2015 X3s, LeeAC, but if you've tried all of the settings with ample water hitting the windshield to trigger the wiper action (perhaps using a hose so that variable can be controlled), then perhaps a trip to your Service Center can identify the problem. Keep us posted if you can.
12-05-2014, 11:08 AM | #3 |
Rep 590
I've always thought the wipers on automatic had a mind of their own. Sometimes for no apparent reason they would start swiping super fast and finally slow down but sometimes I had to take them off automatic and it sort of reset the wiper brains.
12-05-2014, 11:14 AM | #4 |
Rep 518
Dodgy gel pack? (Part of the sensor behind the mirror - I had my windscreen replaced and the gel pack is not OEM so I found my wipers less sensitive as a result). You should still have 3 options - auto, slow and fast though.
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
12-05-2014, 12:16 PM | #5 |
Rep 2,323
The scroll wheel on the stalk does not control speed, it controls the sensitivity of the rain sensor, downward is the most sensitive. One push up of the stalk will activate low speed, one more push is fast speed. Push the button on the side again and it goes back to rain sensing mode.
12-05-2014, 01:17 PM | #6 | |
Rep 66
12-05-2014, 02:11 PM | #7 | |
Rep 2,323
12-05-2014, 03:28 PM | #8 | |
Rep 244
12-06-2014, 04:37 PM | #10 | |
Rep 66
I tried to adjust this today (rain, lucky me) and it made no difference to sensitivity. Thanks for the input - I'm going to ask the service center to check mine next time i go in. |
12-07-2014, 09:12 AM | #12 |
Rep 2,323
The sensitivity real do not change that much with the knob, but if I remember right, up is the most sensitive, please correct me if I am wrong.
12-08-2014, 10:43 AM | #13 |
Rep 180
Never had a BMW before but use the Auto mode mostly. However I was surprised how slow position 2 was - I have an LCI. The stalks don't have clicky positions so I assume I press up twice to get fastest speed?
Also rear wiper only has intermittent wipe from what I can see? Also it seems that I have to turn on and off again to get the rear wiper functional again after turning car off even if left in on position. Again might be not used to BMW's... so any advice appreciated. |
12-10-2014, 06:08 AM | #15 |
Rep 180
Understood but it is a little annoying that if the wiper switch is rotated into on position and left there it doesn't automatically put the rear wiper on when you restart. You have to turn switch on and off to get working again... #firstworldproblem
12-10-2014, 07:15 PM | #16 |
Rep 45
I can see bounderboy that you have LCI model of the X3 so I really am not sure how it works in your car. I've got 2011 and I have to push the leaver down to start the rear wiper and the leaver stays in that position but to tell you the truth I have never checked if it works after I shut the car off and start it again. I will check that later though.
12-16-2014, 02:56 PM | #17 |
JJK0703
Rep 5
Rain Sensing Wipers are a Joke!
It is actually quite comical how bad the rain sensing wipers are on my BMW X3. Any modern car company would be embarassed to provide a feature that works this badly. Intermittant wipers are obviously the way to go today, since therain sensing ones don't work, period
01-13-2015, 07:38 AM | #19 |
Rep 15
Similar wiper speed issues
My 2013 2.8 X3 has similar issues concerning wiper speed and a "mind of their own". I generally use the auto sensing feature - and that works well about 50% of the time. Sometimes it slows down and I can't see - causing me to manually flick on the control stalk and sometimes it starts getting faster and faster even when the rain or my car speed havent really changed. When that happens, I just turn it off and back on. It then seeks to be OK (at least for a while)
My bigger complaint is with the wiper blade designs themselves. The driver side wiper cannot seem to totally get rid of the water on the down stroke, it ALWAYS leaves a big streak of water at the end of the blade - right down the middle of the windshield. The passengers side wiper does not do that! |
01-13-2015, 08:41 AM | #20 |
SPEED RACER
375
Rep 740
I have a trick for when you place it into auto. When the auto mode has a mind of its own, change the sensitivity when it is auto by going from one extreme to the other and back on the sensitivity scroll and then set it to where you want it and that fixes it all the time.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black |
01-13-2015, 12:20 PM | #21 | |
Rep 66
01-13-2015, 12:20 PM | #22 | |
Rep 66
