02-21-2012, 12:52 PM | #1 |
Captain Unsensible
99
Rep 737
Drives: 2016 M240i Coupe - Estoril
Sports Plus Mode question
Hi..
I've yet to try Sports Plus mode because I'm a little unsure as to what it enables or disables from a stability control angle. Enabling it shows up a yellow symbol which suggests DSC or similar has been disabled, yet I have read various comments that suggest it doesn't, but just alters the limits. The manual doesn't really give much away.. so the question is, when you enable Sports Plus what is it actually doing? Is it a mode that allows you to drive it even more sportier, but if the X3 actually looses traction on a corner or you push it a little too far it will still step in a attempt to correct the infraction. Thanks |
02-21-2012, 12:56 PM | #2 |
Rep 1,732
I believe sport + like you mention turns of DTC which allows for some slip but if the computer sense it's getting out of hand it will react and assist and try to regain stability. At least this is my understanding.
02-21-2012, 01:03 PM | #3 |
user
Rep 229
Actually, the way it reads, DTC is active, it's DSC that is turned off - whether it is fully and completely "off" I don't know.
If indeed DSC is fully disabled, there should be no correction in the case of taking a corner too hot. |
02-21-2012, 02:01 PM | #4 |
Captain Unsensible
99
Rep 737
I think they need to disconnect TMA (Too many acronyms!) too confusing now!
02-21-2012, 02:05 PM | #5 |
Rep 3,855
Some of this was covered by Lotus7 and Nahoa in another thread - may help
http://x3.xbimmers.com/forums/showpo...15&postcount=2 http://x3.xbimmers.com/forums/showpo...69&postcount=7 I thought that Sport to Sport+ only switched off DSC activating DTC. No other changes
02-21-2012, 02:28 PM | #6 |
Captain Unsensible
99
Rep 737
Thanks all I'm still no more comfortable enabling it on wet roads in case I end up in a ditch
02-21-2012, 04:06 PM | #7 |
Rep 3,855
There's always that SOS button if that happens
02-21-2012, 05:48 PM | #8 |
Rep 274
I don't think the name implies what is going on. When you go to Sport+, or otherwise enable DTC it allows the vehicle to spin the wheels with less interference from the computer. However, the computer still fully interferes when it detects excessive yaw (spinning).
02-21-2012, 06:30 PM | #9 |
Criminally Insane
53
Rep 1,464
Drives: Like a Demon!
I have always considered Sports+ to be like the MDM button on an M car.
It sharpens the steering / throttle/suspension responses (depending on the options you have fitted obviously) and loosens the nanny controls to let you have more fun, but doesn't leave you totally nanny free. (as you get when you press and hold down the DSC button - When you get flashing DSC warnings and a big banner ont he iDRive display)
Dr Stig 2010 Z4 35is 2011 X3 30d M Sport Australia |
02-21-2012, 09:07 PM | #10 |
user
Rep 229
02-21-2012, 09:51 PM | #11 |
X3 Owner/Driver
212
Rep 785
Drives: 2018 X3 M40i
you can turn off DSC and DTC by holding down the DTC button for 10 seconds I think - which turns all traction control off, which is what will lead you to a ditch
most of the time I use sport not sport+
2018 X3 M40i G01 | Phytonic Blue | Mocha | Premium+Exec | Driver Assist | Adaptive M Suspension
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience [traded in] 2008 328XI E91 Sportwagon l Sparkling Graphite [traded in] |
02-22-2012, 02:40 AM | #12 |
Rep 125
I use sport+ when I want some fun. Otherwise normal mode serves me just fine.
Know your limits and your car's, and you will be on the road, not in a ditch even if you have none of those electronics. |
02-23-2012, 09:51 AM | #13 |
Rep 1,781
And again
When SPORT+ is selected, Dynamic Traction Control (DTC), which activates variable torque split allowing for more spirited driving, is turned on. Dynamic Stability Control (DSC) remains on unless you turn it off by holding the DSC button just north of the shifter for a number of seconds. SPORT+ will always offer some assistance should it sense an impending loss of control, unless DSC has otherwise been deactivated.
02-23-2012, 07:09 PM | #14 | |
Rider and driver
141
Rep 506
If my reading comprehension hasn't failed, DTC and DSC are both on by default until specifically turned off.
2021 X3 MC
I work for Keyser Söze |
02-23-2012, 09:33 PM | #15 |
Rep 1,876
For what it's worth I can confirm, after tonight's commute, that Sport+ allows some wheel spin and the 35i goes like a bat outta hell at red line . . .
02-23-2012, 09:49 PM | #16 |
Rider and driver
141
Rep 506
Closed course, professional driver I take it.
2021 X3 MC
02-26-2012, 04:53 PM | #19 | |
Rep 1,781
The warning icon is misleading because BMW uses it for both DTC ON and DSC OFF. BMW does this because where DTC ON makes for less stability (but more loose-surface traction) in corners and under acceleration, DSC OFF deactivates all driving dynamics assists, making for even less stability in corners and under acceleration. Your reading comprehension hasn't failed you. BMW would sooner declare a reintegration of the aeronautic technologies they produced under contract with Hitler for the German Nazi Regime than provide an actually comprehensive owners' manual. |
02-26-2012, 05:25 PM | #20 | |
Rider and driver
141
Rep 506
2021 X3 MC
02-26-2012, 06:02 PM | #21 | |
user
Rep 229
From the manual:
02-26-2012, 08:20 PM | #22 |
Rep 1,876
Matches my understanding and what I understood from juddholland's posts.
