      06-24-2012, 01:42 PM   #1
Eurocar11
Drives: 2013 X3 2.8
Error when coding. Can anyone decipher?
Attempted my first re-code of the X3 and encountered an error. Have a working cable, all the software, etc. Connects to the car fine & acknowledges the VIN. All seems to work fine up to the very end when I get an error. Hopefully someone can assist.
I am following the step-by-step instructions from one of the other BMW Fxx series sites. Our X3 has the Comfort Access on the door handles. I'm trying to code it so the mirrors fold with a long hold of the key fob or a long hold of the door handle ridges.
I follow the instructions to the letter and all seems well until I get to the "CODE FDL" part. The instructions say to "Select the CAFD file you just edited and then click "CODE FDL." I do so and the CODE FDL progress window appears. When it completes, the following error appears:
Transaktions-Report: Aktion: FDL Codieren
Abort!
Asynchrone programming failed! [C049]
openECUConnection for link BKOMBI_60_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name BKOMBI_60_ETHERNET doesn't map to an item [1694] - VEHICLE_ERROR
For those software/coding experts out there, do you have any ideas/suggestions?
      06-24-2012, 02:44 PM   #2
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Nothing to worry, nothing has affected your car.I am not expert but tried successfully couple of times.
I don't know what went wrong but try following steps ( I assume that you have correctly installed the correct software on lap top having win xp or win 7 and have created all the blank folders for each Fxx. And linked EST properly in E-Sys Options > Settings > EST to the correct folder to Code Away.est.)
1. Switch off any wifi or Bluetooth of your laptop, let's have only one network connection from your car to your laptop. Good practice.
2. Switch off firewalls too, behaviors of different virus detecting SW is unpredicted. Good practice.
3. Connect ENet cable from your car to laptop, Switch ignition and wait for limited connectivity to be established. Ensure that laptop has full power and car battery is also fully charged.
4. Run ZGW_SEARCH of EDIABAS to see that VIN number gets displayed.
5. Start E-Sys
6. Press connect button, select the correct series. It should be F025 for you and connect.
7. Read VO
8. Select FA and Read VCM
9. Select the Expert Mode and Coding button on left pane. Now select the right CAFD and read Coding Data, it will get you the fresh copy of the data from car.
10. Open the created folder and select the CAFD and right click to edit it, enter pin when asked for it.
11. Make changes and press the save button
12. Come back to SVT by pressing tha green back arrow on top
13. Right click on FA to activate it
14. Go back to the edited CAFD and right click to select Code FDL.
This should complete the task and give you success.
15. Disconnect connection by clicking top connection button and take off cable.
16 you should be ready to go.
      06-29-2023, 09:10 AM   #3
tgaspl17
Drives: BMW 523i
Did you manage to get this problem fixed? I have a similar problem while trying to code CAFD into KOMBI or flash KOMBI.
This is the log file
Read SVT before TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated.
<run()-> Value of 'httpServerActivation': true>
<run()-> Value of 'isDeactivateHttp': false>
<[MULF - 55] Could not read ComParam 'MODE_CHANGE_PARAMETER'. Maybe the template is too old. [WARN]>
<[MULF - 55] - [Exception] Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name MODE_CHANGE_PARAMETER doesn't map to an item'>
<[MULF - 55] Could not read ComParam 'HTTP_BTLD_FLASH_ENABLED'. Maybe the template is too old. [WARN]>
<[MULF - 55] - [Exception] Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name HTTP_BTLD_FLASH_ENABLED doesn't map to an item'>
<[MULF - 55] Could not read ComParam 'IDR_REQUIRED_BEFORE_FLASH'. Maybe the template is too old. [WARN]>
<[MULF - 55] - [Exception] Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name IDR_REQUIRED_BEFORE_FLASH doesn't map to an item'>
<[MULF - 55] Could not read ComParam 'SUPPORTS_OPTIMIZED_BTLD_UPDATE'. Maybe the template is too old. [WARN]>
<[MULF - 55] - [Exception] Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name SUPPORTS_OPTIMIZED_BTLD_UPDATE doesn't map to an item'>
<ExecutionID=2023/06/23-11:51:32.949>
<[] prepareTALExecution started [PROGRESS]>
<[] prepareTALExecution finished [PROGRESS]>
<[] null [THROWABLE]>
<[] prepareVehicleForCoding started [PROGRESS]>
<[] prepareVehicleForCoding finished [PROGRESS]>
<[KOMBI - 60] prepareECUforCoding started [PROGRESS]>
<[KOMBI - 60] prepareECUforCoding finished [PROGRESS]>
<[KOMBI - 60] authenticateECUforCoding started [PROGRESS]>
<[KOMBI - 60] authenticateECUforCoding finished [PROGRESS]>
<[KOMBI - 60 - cafd_00000069-009_001_006] Transaction type: cdDeploy; Message: TA started [TRANSACTION]>
<[KOMBI - 60 - cafd_00000069-009_001_006] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]>
<[KOMBI - 60] finalizeECUCoding started [PROGRESS]>
<MCDDiagService<id=80714, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : generalProgrammingFailure, link=KOMBI_60_ETHERNET> [DIAGSERVICE]>
<[KOMBI - 60] finalizeECUCoding error [PROGRESS]>
<[] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_CPS returned a negative response with response code generalProgrammingFailure; LinkName: KOMBI_60_ETHERNET
severity: ERROR
[THROWABLE]>
<[KOMBI - 60] There was an error during TAL execution, please check the log files. [WARN]>
<[KOMBI - 60] - [Exception - KOMBI - 60] job failed with negative response error:
severity: ERROR
<[] finalizeVehicleCoding started [PROGRESS]>
<[] finalizeVehicleCoding finished [PROGRESS]>
<[] finalizeTALExecution started [PROGRESS]>
<[] Finalization of TAL execution failed with exception [WARN]>
<[] - [Exception] negative response error:
code: exception in job
description: MCDException in Job MCD3_FinalizeTALExecution, Context: service ReadDataByIdentifier ActiveDiagnosticSession, Type: com.bmw.prodias.exceptions.mcd.ParameterizationExc eption, Message: Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name SERVICE_PACK doesn't map to an item', [Severity=2051][ErrorCode=49184][ErrorCodeDescription=Object with name not found][VendorCode=3][VendorCodeDescription=provided name SERVICE_PACK doesn't map to an item]
severity: ERROR
<[] finalizeTALExecution finished [PROGRESS]>
<TAL execution finished [TAL_EXECUTION_FINISHED]>
TAL-Execution finished with status: "FinishedWithError".
TAL execution finished. Duration: "9s".
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
      06-29-2023, 10:58 PM   #4
TheNine90
Drives: bmw
What the cluster replaced?
      10-06-2023, 05:19 AM   #5
redog4dy
Drives: F10 525d, 2012
Hello, sorry to resurect an old thread.. any solution for below? Ethernet.. vo code kafas1 , f01 2009.
<talLine id="tl_1" status="FinishedWithError" diagBus="FA_CAN" baseVariant="KAFAS" diagAddress="5D" endTime="20231005-133712.472" startTime="20231005-133710.157" cause="ta_1" intelligentSensorsFiltered="false">
<preparation endTime="20231005-133711.843" startTime="20231005-133711.458" status="Finished" id="prep_2"/>
<authentication endTime="20231005-133712.203" startTime="20231005-133711.843" status="Finished" id="auth_2"/>
<finalization endTime="20231005-133712.470" startTime="20231005-133712.377" status="Finished" id="final_1"/>
<cdDeploy cause="ta_1" id="tg_1" status="FinishedWithError">
<cdDeployTA endTime="20231005-133712.376" startTime="20231005-133712.203" cause="excep_3" id="ta_1" status="FinishedWithError" isSensorSW="false">
<sgbmid>
<processClass>CAFD</processClass>
<id>00000122</id>
<mainVersion>003</mainVersion>
<subVersion>002</subVersion>
<patchVersion>037</patchVersion>
</sgbmid>
<ncd>
<content>S00A000000000122030225A8
</content>
<signature>[0, 0, 0, 32, -105, -42, -35, -113, 109, -4, -66, -109, 2, 94, -87, 112, -32, -90, -10, 13, -101, 120, -69, -41, -126, -21, -76, -45, 49, 124, -43, -16, 18, 102, -84, 52, 126, -70, 108, 8, -65, -33, 22, -99, 127, 119, 90, -74, 1, 3, 99, 30, -85, 49, 58, -75, 28, 73, 55, -77, -107, -99, -76, 68, -98, 118, 18, 43, -61, 90, 97, -68, -8, -18, 64, -64, 91, -112, 22, -51, -113, 5, 37, 117, 47, 44, -68, -59, -91, 122, -74, -101, -92, -90, 37, -112, 35, -128, 54, -35, 1, -18, -72, -80, -86, 46, 44, 42, -29, 52, -89, -73, -117, -40, -91, -48, 93, 88, 72, 101, 127, 92, -86, -100, -43, 53, 30, -9, -122, -96, -72, 94]</signature>
<signatureaddress>12545</signatureaddress>
</ncd>
<Throwable timestamp="20231005-133712.376" id="excep_3">
<MsgId>433</MsgId>
<MsgText>job failed with negative response error:
code: repeat job
description: Service WDBI_PLAIN returned a negative response with response code generalProgrammingFailure; LinkName: KAFAS_5D_ETHERNET
severity: ERROR
</MsgText>
<MsgArgs>
<MsgArg>negative response error:
code: repeat job
severity: ERROR
</MsgArg>
</MsgArgs>
<PackageName>com.bmw.psdz.vehicle.connection.uti l</PackageName>
<ClassName>ResultUtil</ClassName>
<ExecutionContext>
<ContextCategory>TAL</ContextCategory>
<ecuID baseVariantName="KAFAS" diagnosticAddress="0x5D"/>
<ContextInfo>
<ContextItem key="TA_CATEGORY" value="cdDeploy"/>
<ContextItem key="PROGRAMMING_STATUS" value="performECUCoding"/>
<ContextItem key="TALLINE_ID" value="1"/>
</ContextInfo>
</ExecutionContext>
</Throwable>
<MCDDiagServiceEvent id="warn_2" timestamp="20231005-133712.293">
<MsgId>1685</MsgId>
<PSdZEventType>DIAGSERVICE</PSdZEventType>
<PackageName>com.bmw.prodias.execution.primitives. mcd</PackageName>
<ClassName>SingleEcuJob</ClassName>
<ExecutionContext>
<ContextCategory>UNDEFINED</ContextCategory>
</ExecutionContext>
<MCDResponseType>NEGATIVE</MCDResponseType>
<JobName>com.bmw.psdz.jobs.uds.MCD3_PerformECUCodi ng</JobName>
<ServiceName>WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value)</ServiceName>
<LinkName>KAFAS_5D_ETHERNET</LinkName>
<ErrorId>62714</ErrorId>
<ErrorName>error: negative response : generalProgrammingFailure</ErrorName>
</MCDDiagServiceEvent>
</cdDeployTA>
      10-07-2023, 10:29 AM   #6
TheNine90
Drives: bmw
Can you give more info. Was the unit replaced?
