      03-25-2012, 11:31 AM   #1
jdmass
Drives: 2012 X3 xDrive35i
DIY: Extremely Simple (But Expensive) Radar Detector Install
After struggling with the center overhead console, I started searching for alternative solutions and came across a new accessory from Valentine One called Savvy (http://www.valentine1.com/savvy/). It consists of a module that plugs into the OBD (on-board diagnostics) port connected to an RJ-11 socket module. The purpose is to provide an alternative power source to the radar detector and also to allow you to set a speed threshold (via a thumb dial on the unit) to automute a Valentine One.
I own an Escort 9500ix, but was thinking of trying the V1 and selling my Escort, so I ordered the combo V1 and Savvy. Not to get into a "which detector is best" debate, I ultimately decided to return the V1, but for kicks decided to plug my Escort into the Savvy (I set the speed on the Savvy thumb dial to none). As a power source, it worked! So I decided to keep the Savvy and installed my Escort to it, and decided to take a few shots to show the installation.
This is literally a 15 minute or less project. It simply involves positioning the detector where you want it, running the power cable along the headliner and tucking it in, fitting and guiding it under the rubber door molding and connecting the Savvy to the OBD port in the footwell.
After a few weeks, it seems to function perfectly -- so, as the title says a really simple, but definitely not inexpensive solution. The good news is that it require not cutting or modification, and is easily uninstalled. My intention is to disconnect the Savvy (unplug and disconnect the detector cable) when bring the car in for service -- a very minor inconvenience.
Jim D.
2015 X3 xdrive28d
Black Sapphire Metallic/Black Nevada/xLine, Cold Weather, DHP, DA, DA+ w/ACC, Lighting, Premium, NAV, HK Audio, Parking Assistant, Enhanced BT
Previous BMWs: 2000 528i, 2003 540i, 2007 335i Sedan, 2009 335i Sedan, 2012 X3 xDrive35i
