02-20-2023, 07:59 PM | #1 |
Rep 11
iPod playlist and radio station control
Hi all,
just bought a 2017 BMW X3 xDrive28i. it appears to have most of the addon packages including technology. Two questions: 1. When I connect my iPod nano, the music plays fine, but I cannot seem to select a specific playlist - just search, artists, or songs selection 2. is there a way to change the radio station with the steering wheel? I know the "mode" button just toggles between the audio sources, but I'd like to just navigate from one station to the next without moving my hands from the wheel. before you mention apple carplay, I do NOT have an iPhone (Google Pixel 6), and would prefer to use the cars integrated system rather than fiddling with my phone and worrying about the bluetooth connectivity. thanks! |
02-21-2023, 10:34 AM | #2 |
Rep 2,547
Welcome to the forum...
1. I use a USB stick with music so can't help with nano playlists. 2. The steering wheel controls can change radio stations, hell, you can even change them with voice commands. Have you even tried using the steering wheel controls? |
02-21-2023, 10:41 AM | #3 | |
Rep 11
really, just want to toggle through the presets - not sure if I have to enable a specific setting. |
02-21-2023, 01:21 PM | #4 |
Rep 11
i figured it out finally!
scrolling the wheel on the right-side of the steering wheel allows me to scroll up/down on the stations/presets. then pressing the wheel selects that station. however, it only shows on the heads up display for me rather than on the nav/radio screen. as for the playlists, I had to select "search" first. but when doing so, it starts to play the first 2 seconds of the song and then gets stuck repeating (like a broken record). I suppose the issue could be with my out-of-date iPod, so I'll try another device. |
02-21-2023, 01:49 PM | #5 | |
Rep 2,547
02-24-2023, 08:49 PM | #6 |
Rep 11
so another update to this - not sure if anyone else has had this experience, but when I attempt to play songs from the iPod nano (4th generation), it takes a while for the car recognize the songs, and even longer to recognize the playlists. this is fine, but what's frustrating is that when attempting to play a song from a playlist, it will just repeat the first 2 seconds over and over again (I let this go for a solid minute before giving up). however, when I use an iPod touch (1st generation), it still takes a bit to recognize the songs/playlists, but it plays them fine. so I'm not sure if there is some sort of software incompatibility issue, but just for others to know in case this helps them.
