02-13-2023, 07:17 AM | #1 |
Rep 12
Can't check oil level when engine is hot
Hi, Can anyone please tell me if this is normal; I can only check my oil level when my engine is well below normal operating temperature. I need to check my oil when when my car has been running for around 10 minutes or so, once the car warms up more than that, it will stop the oil level check around 17 to 20%. Can anyone please confirm if you are able to check your oil level after your car has been running for more than 20 - 25 minutes? I asked 2 BMW mechanics and they couldn't answer me because they are usually working on cold cars and just let the car run long enough to get the engine warm, not hot. I have a 2013 4 cylinder X3. Thanks
02-13-2023, 11:27 PM | #2 |
Rep 27
I have this exact issue with my 2013 6 cyl N55 as well. I have yet to replace my oil level sensor to confirm if that is the issue. But on my last oil change, I only poured 6qt just to check and indeed it did send a warning that I'm a quart short after about 2 minutes of running.
02-14-2023, 07:07 AM | #3 |
Rep 660
When hot the vehicle is not building enough oil pressure and the oil level check aborts. My guess since you have an N20 is you likely need the timing chain replaced. There may be timing chain debris in the oil pump pickup. It could also be a defective oil control valve on the side of the engine near the oil pump or just a bad oil pump. Minus the timing chain, the same applies to the N55. Eventually on either engine you will cross the threshold to trigger an oil pressure warning.
02-14-2023, 07:19 AM | #4 | |
Rep 12
02-14-2023, 07:22 AM | #5 | |
Rep 12
02-14-2023, 10:42 AM | #6 |
Rep 2,547
Curious why you created another thread about the same issue for the thread you created last month? Doing so looses the previous discussion history
https://x3.xbimmers.com/forums/showthread.php?t=1983786 |
02-14-2023, 11:38 AM | #7 | |
Rep 12
02-14-2023, 03:10 PM | #8 |
Rep 119
Mine just started doing this. N55 with 117k miles. It reaches around 20% then stops. I recently did an oil change too.
Haven't done any repairs to the car recently, I'll keep an eye on this thread if anyone has a solution. |
02-14-2023, 03:56 PM | #9 |
Rep 104
I have an n20 and I check the oil when the motor is hot. I am not sure the year of the motor as the dealership installed a new out of the crate n20 when I bought it two years ago
02-15-2023, 01:41 PM | #10 |
Rep 12
FYI, I just did a reprogram and that didn't work either, so I'm going to let it go for now. I'm going to keep checking the oil when it's warm (not hot) and hope that it tells me when it's low. I should know soon, as I do burn a little bit of oil.
02-20-2023, 07:06 AM | #11 |
Check out my Youtube @n55david!
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
You need to change the sensor.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-22-2023, 01:36 PM | #12 |
Rep 12
