02-02-2023, 03:21 PM | #1 |
Rep 5
Recommended services and cost for 2017 X3
I have a 2017 X3 x28i. My vehicle has 56k miles on it. Any recommendations what are the recommended services? I read somewhere that spark plugs, transmission fluids needs to be changed somewhere around 60k. Is that all? If yes, what would be the rough cost? I am based out of Bay Area.
02-03-2023, 08:16 AM | #2 |
Rep 2,908
No idea on cost since I DIY, but around those miles I would change the tranny fluid, front and rear diff fluids, transfer case fluid, brake fluid if not done in the last 3 years, plugs (coils up to you), and then have a careful inspection done for oil leaks and worn suspension and driveshaft components.
02-03-2023, 09:11 AM | #3 | |
Rep 7,485
02-03-2023, 11:24 AM | #4 |
Rep 2,908
I will also add that I would swap the belt (tensioner pulley optional) if not already done because it is so easy to do on those engines, unless it has no micro-cracking at all. Note that what QSilver posted will never say to change tranny or transfer case fluids because BMW calls them "lifetime." No thanks. Whether you want to do that depends on how long you intend to keep the car. If you are selling it by 75k miles, then I wouldn't. But if you are keeping it for another 50k miles, I would.
03-03-2023, 01:13 PM | #5 | |
Rep 906
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
03-03-2023, 01:50 PM | #6 |
Rep 2,547
I'd go by the trans manufactures recommendation of every 80,000-120,000 km, they probably know best. The whole BMW lifetime fluid thing is to lower cost of ownership by reducing maintenance cost, but do as you wish
03-07-2023, 10:14 AM | #7 |
xdriv33
69
Rep 218
Drives: 17' BMW x3 F25 xDrive28i xLine
that is total BS.... lifetime fluid? ya sure buddy. More like become a life time customer of a BMW dealership so you can replace your vehicle's trans and other components once they break down due to fluids not flushed and refilled.
