09-12-2013, 10:57 AM | #1 |
Rep 66
Rear light cluster Clips broken
Has anybody had any problems with the rear light cluster clips ?, mine have both broken and cluster is loose. Problem is on nearside cluster, there are two plastic clips which attach the cluster to the bodywork. The first clip broke a couple of months ago and now the other one has done the same.
Suspect that the problem is due to the air pressure when the tailgate is closed, could be that the bump stop is misaligned as have not yet had a problem with offside. There is no rubber between the plastic clip and metal to absorb vibration and there does not appear to be much damping when the tailgate is closed. |
10-11-2013, 08:27 AM | #3 |
Rep 3
I probably open the boot 2/3 times a day and have to say I'm none to gentle but so far (touch wood) had no problems with these clips. Might just be good luck so far but will probably be a little gentler in closing the boot from now on!
Electric Seats, Prof Media, Visibility Pack.
Servo + Variable Sports Steering, Variable Damper Control, Enhanced Blue Tooth, Extended Storage, Heated Seats, Internet, Run Flats, Sun Protection Glass. |
