      07-10-2021, 05:21 PM   #1
spelk3
Confused Member
spelk3's Avatar
Drives: BMW X3,i3,i3; Harley FLSTF
Add Sport+ using BimmerCode?
Hi,
Does anyone know how to implement the Sport+ mode using the DEC switch with BimmerCode? It’s not a precoded function for the X3. I’ve only got eco-pro, comfort and sport.
      07-11-2021, 08:55 AM   #2
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Originally Posted by spelk3 View Post
Hi,
isn't just under the trans ecu section?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-11-2021, 12:49 PM   #3
spelk3
Confused Member
spelk3's Avatar
No. Only have sport automatic transmission. Sport+ isn’t listed anywhere.
I’ve actually emailed BimmerCode and they said it can’t be done. I thought I’d see if anyone had figured it out.
www.bimmer-tech.net sells code to do it but I don’t want to pay $150 just to code Sport+. ($99 plus $49 for adapter).
      07-11-2021, 01:44 PM   #4
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
No. Only have sport automatic transmission. Sport+ isn't listed anywhere.
I've actually emailed BimmerCode and they said it can't be done. I thought I'd see if anyone had figured it out.
www.bimmer-tech.net sells code to do it but I don't want to pay $150 just to code Sport+. ($99 plus $49 for adapter).
I was gonna day xhp will do it but if you don't wanna spend any money, then I dunno.
there is a coding thread here already, it will be in there.
      07-11-2021, 02:48 PM   #5
spelk3
Confused Member
spelk3's Avatar
I already have xHP, MHD, BimmerCode and BimmerLink. Just can’t see spending that much for a single coding update.
      07-11-2021, 07:21 PM   #6
pungo
pungo's Avatar
Did you VO code 205 to 2TB, then code KOMBI/ICM/EGS ?
      07-11-2021, 07:39 PM   #7
spelk3
Confused Member
spelk3's Avatar
No. I’m assuming this is done with the expert mode in BimmerCode? Are there easy to find instructions anywhere?
I do have Sport Automatic Transmission set to active using BimmerCode.
BimmerCode told me it was not possible to add Sport+ even coding using expert mode.
      07-11-2021, 07:55 PM   #8
pungo
pungo's Avatar
BimmerCode told me it was not possible even coding using expert mode.
Sorry, wasn't aware of it's limitations, I don't use bimmercode for coding. Use e-sys instead
      07-11-2021, 08:44 PM   #9
spelk3
Confused Member
spelk3's Avatar
How do I get e-sys? How does it connect? I’ve got both WiFi and Bluetooth OBD2 adapters.
      07-12-2021, 04:05 AM   #10
spelk3
Confused Member
spelk3's Avatar
I’ve got e-sys and an ENET cable ordered.
You wouldn’t happen to have instructions on how to enable Sport+ mode, would you?
Thanks,
Steve
      07-12-2021, 01:26 PM   #11
pungo
pungo's Avatar
Thanks,
Steve
Here's the guide: E-Sys User Guide.pdf
Change VO from 205 to 2TB
Then code KOMBI/ICM/EGS
      07-12-2021, 01:57 PM   #12
spelk3
Confused Member
spelk3's Avatar
Here's the guide: Attachment 2647378
Thank you, much appreciated!
      07-12-2021, 11:58 PM   #13
spelk3
Confused Member
spelk3's Avatar
One more question, what coding value changes do I need to make to KOMBI, ICM and EGS?
Thanks!
      07-14-2021, 05:41 PM   #14
spelk3
Confused Member
spelk3's Avatar
Got Sport+ working.
Coding with esys messed up some of the other coding I had done with BimmerCode. So I had to recode them. Also set off brake ABS warning after coding but that seems to have gone away.
BimmerCode is much easier to use than esys but can’t do as much.
      07-14-2021, 06:45 PM   #15
pungo
pungo's Avatar
Got Sport+ working.
Good you got it working
Anytime you change the VO and code the applicable modules, you loose any custom coding for those modules since it writes the defaults to them. Now if you make a backup of the \data\CAF\CAFD*.ncd files you'll be able to able to restore any coding you have done.
If you load the "FDL Cheat Codes" in launcher, you get a bunch of custom coding options to select from.
