      06-28-2021, 09:02 PM   #1
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Rear tail light lens
My wife backed into something and cracked the rear turn lens in the quarter fender, not the tail gate. Our car has the LED tail lights with front adaptive lighting. I found the cheaper NON LED turn lens. Can I swap my good LED panel into the non LED lens. Thanks for any help…
      06-28-2021, 10:55 PM   #2
WagonR
Drives: 2017 M2
Probably not the most help, but I think the taillamps have the lens glued to the housing, so you'd likely have to cut it off. Since you're sacrificing the LED lens, and the non-LED housing, you should be able to do it okay, but I'm guessing it's a lot of work.
To your question; I'm not sure if the lens is the same LED vs. not LED. Probably, because they wouldn't want to design multiple versions of the same part, but I don't know for sure.
Good luck!
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
      06-30-2021, 03:18 PM   #3
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
I pulled the trigger and will see if it will work. If not it has free returns…
      07-01-2021, 12:18 AM   #4
sbabcock23
Drives: '17 X3
I would be interested in what you find out!
