      06-23-2017, 06:24 PM   #1
gc3
Drives: 2015 x35i
Experiences with Lift Kits?
This post is about raising, not lowering.
I've ordered Eibach Pro-Lift-Kit (raises up to 30mm) and Bilstein B6 Offroad shocks. Checked with manufacturers to make sure they play together appropriately, at least by specification. Intent is to have the X3 be ever so slightly more usable off-road. Maybe the whole thing will ride better, who knows.
Any thoughts or opinions?
2015 X3 xDrive35i Space Gray: ZDA | ZDB | ZPP | ZTP | Heated Seats | 309 wheels | coded
      06-26-2017, 11:55 AM   #2
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
I had the same thought in mind. I purchased the lift kit and Bilstein B6 shocks/struts. The local tire dealer order a larger tire ~5% with an all terrain tread. Between the lift kit and tires I would have increased the ground clearance by about 2 inches, total ~<10inches. We did a trial fitting of the new front tires. Just not enough clearance without cutting part of the inner fender. Without spare time to give it, i just said screw it and installed the shocks/struts with new Bridgestone run flats. There is a guy with an X1 in Los Angeles that posts somewhere, sorry forgot what forum that "off roaded" it with Eibach, etc. Really liked the outcome. BTW, the B6 is not an "off road" shock/strut. It is a performance shock. Thought so at first also. Car handles MUCH better with the B6 shocks/struts.
      07-01-2017, 07:57 AM   #3
gc3
Drives: 2015 x35i
Thanks for the input. I figured to just stay with the OEM 19" wheels and not get too aggressive with tires. And the worst that can happen is better handling as you experienced. Did you wind up not installing the Eibach springs?
      07-07-2017, 11:40 PM   #4
335iAP
Drives: AW E92 & F26
I've been interested in doing this to my x4 since seeing an off-road style X6. I settled for larger tires for now. Sits about an inch higher, and rubbed just a bit but I eventually cut out part of the fender liner. It's replaceable should I ever want to go back to stock. [IMG][/IMG]
      07-07-2017, 11:41 PM   #5
335iAP
But on the point of riding better - I can only speak for tires, but it rides much, much better on bigger tires.
      07-24-2017, 08:36 PM   #6
Bimar
Bimar's Avatar
800
Drives: Bmw X
Any changes in stability of the car?
      07-24-2017, 10:32 PM   #7
335iAP
Not that I've noticed, to be honest. I'm sure if you went and tested it there might be a difference, but it's negligible if so and offset by how much less unstrung weight there is without such heavy wheels at all four corners. I do long, hour+ highway drives pretty often, and the car is smooth, quiet, and stable at 80 mph. Our roads are pretty good, but the tires soak up whatever imperfections there are. Even so, I may go back to 19s or 20s in the future with the tires a single size larger than stock, just to change up the look.
Any updates on the lift kit? I'm interested in seeing pictures, since I'm not sure if the X4 is too narrow to pull off the lifted look.
      07-25-2017, 09:26 AM   #8
Lurcher
Lurcher's Avatar
Drives: 2012 z4
Who cares about the ride - M-pars !!!!!!!!!!!!
I miss my e38...
      07-25-2017, 09:38 AM   #9
335iAP
I miss my e38...
Definitely a cool looking set of wheels. Easy to clean too.
      08-09-2017, 11:00 AM   #10
335iAP
Any updates here? Really considering a small lift, but I think I would need wider tires to balance out the look and that's not in the budget right now.
      04-21-2018, 09:38 AM   #11
dralanglez
Drives: 2015 BMW X3
X3 F25 lift
About to embark with the Eibach Pro-Lift-Kit and AT BF tires but have not decided about shocks - any recommendations for shocks? where to order? appointment in 3 weeks at trick trucks
      06-06-2018, 09:44 AM   #12
andrey.kvotchenko
Drives: 2014 bmw x3 f25 28i
Mine has the 18inch wheels. Has anyone ever put larger tires without lifting it.
I was thinking maybe 255/55r18
      06-12-2018, 03:45 PM   #13
nelsonnrc
Drives: X3 F25
Any updates? Can you send some pics?
      06-13-2018, 07:47 AM   #14
335iAP
Also hoping to hear more. Was close to pulling the trigger on the springs but decided tondo performance mods first.
      09-19-2019, 09:49 PM   #15
fadixrv
Drives: BMW X3 2017
Hi folks. please any update or pics on the X3 lift and all terrain tires. am very keen to do it. would love to be able to take on forest service roads and still be in my Bimmer
i dont want to take hard offroadt at all. i know this car isnt meant for that, but just some little more ground clearance and rugged tire confidence
thanks
      09-20-2019, 07:38 AM   #16
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
thanks
I've got some brand new Eibach Pro-Lift-Kit springs that I'm not going to use. I'll sell them to you for cheap. PM me.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      10-04-2019, 01:52 PM   #17
bodiax3
Drives: BMW X3
Hey guys, I see some wondering about bigger tire sizes. I also was looking to make my x3 more offroad capable, and started with the tires. With installing 2" spacers, I fit 245/65/17s on, with just the slightest tire rub at full turn, and i'd say that without a lift thats probs the biggest that will fit. Im alsoo interested in lifting it, so if anyone knows any spacific part; springs, spacers, struts, plz let me know
this is what it looks like with new tires and spacers
      10-05-2019, 08:13 AM   #18
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Looks like you're in a first generation X3, but looks good.
      10-05-2019, 08:15 AM   #19
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
If anyone's interested in F25 lift springs, I have a pair for sale here.
https://x3.xbimmers.com/forums/showt...php?p=24456862
      12-06-2021, 02:57 PM   #20
bryso21
Drives: e46 M3
Thought I’d bring this thread back to life with some visuals
Just installed 4x 265/50R19 on my 2012 X3 35i and she rubs on the drivers side on left lock.
SO I’m looking at raising it a little to fix this issue.
When I bought this vehicle I had 245/45 on stock 19” wheels now I have 19” Apex Arc-8s 9.5” wide and a ET 22 offset all around. Looks fantastic and rides so well, also entry height is perfect, not climbing into the seat. I’m 5’10” and it’s an easy side step into the vehicle.
Has anyone done the lift springs?
Also has anyone heard of these spacers that go between your springs and struts eliminating the need for lift springs. They say they are manufacturer Ok'd
https://www.spaccer.com/en_CA/makes-...els/bmw/x3-313
      12-07-2021, 10:48 AM   #21
Don T
Drives: 328 and f-25
Installed 245-55-18 on my 2017. Went with the General G-Max Justice, all season. Use my X-3 quite a bit off-roading in So. Cal. deserts. Am an avid quail and chukar hunter. Slightly more ground clearance and much improved ride.
      08-02-2022, 02:57 AM   #22
Tweaksta
Drives: 2011 BMW X3 F25 30d M Sport
What about combining the raised springs with strut spacers to try and get more than 30mm?
