      06-24-2017, 10:42 PM   #1
frisbeeguy
Drives: BMW,Tesla, etc.
New First time BMW owner question
Hello Everyone,
I recently acquired a used 2007 BMW X3, and I like it a lot so far. Of course since its at 100K, I plan to change the diff fluids, transfer case fluid, transmission fluid (change only by dropping the pan, cleaning it, installing new fluid and filter), and powersteering fluid (in the future, but looks good to me). The coolant is good, and I do have all the service records from when it was bought to this year. Although it seems the previous owner bought into BMW's "lifetime fluid."
I've primarily driven and fixed VW, and with VW, I use VCDS for diagnostics, real time data, coding, adaptations, etc. I researched into similar software for BMWs and I came across Rheingold ISTA-P (http://rheingoldusa.com/conc/index.p...egory=16152035) (http://rheingoldusa.com/conc/index.p...egory=20084013), and INPA. Which software would you all recommend? Would I be able to use ISTA for diagnostics, coding, etc like how I can use VCDS on VW? Also, if ISTA is good, should I buy the first link package or second link?
Another question: Any good looking double din aftermarket dash kits for the E83? So far I only see single DIN.
I also appreciate any tips and advice for anything else related to my car. Thanks
      06-25-2017, 07:34 PM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
Drives: M4 Coupe | M3 | Z4M Roadster
Did you know that there is a specific forum for X3 owners? You might want to try and post your questions there as more X3 owners will seet them: http://x3.xbimmers.com/forums/index.php
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      06-25-2017, 08:23 PM   #3
frisbeeguy
Ok. I'll post in the First Generation forum. Thanks.
      07-12-2017, 02:00 PM   #4
DBU
DBU's Avatar
233
Drives: 2022 X4MC - Marina Bay Blue
Originally Posted by frisbeeguy View Post
Hello Everyone,
You can obtain ISTA for free - check out coding section the "other forum" - tons of good coding info and help there.
What is a "DIN?"
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup).
Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport
      07-20-2017, 12:56 AM   #5
frisbeeguy
Thanks,
I'll look into ISTA.
A DIN is a 2" x 8" opening (once you pull out the radio headunit), and the term is often used in the aftermarket stereo industry. E83 first gen is only single DIN, and the air vents take up too much space, so a double DIN (4" x 8" opening) headunit won't fit. I'll just convert the storage compartment on the top to put a Double DIN (future project)
