      08-18-2015, 04:33 PM   #1
DonC
Drives: 2013 X3 3.5i M sport, etc
Back from the dealer
SA says that the oil filter housing gasket is starting to leak and they estimate it will cost $866.27 to correct this issue. SA said that the next item will be the valve cover gasket will need to be replaced.
Anyone have experience with these oil leaks? I have a 2013 X3 3.5i with 70 K miles and I am the OE.
While I'm at it the SA also says the tail gate lift motor is going out(it is making noise) and that will be $725.50 installed.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
