11-16-2020, 09:04 PM | #1 |
Rep 119
F25 RPM RISE on its own while at stop light.
Hi all, I've noticed my 2017 X3 35i has an un-commanded RPM rise while stopped at a light. This happens all on its own (I'm not pressing the accelerator pedal accidentally with my foot on the brake) it goes from about 650RMP to about 800-900RPM for a second or two and then comes back down. It even does this with the climate control turned off- not the A/C compressor cycling on and off. I ran diagnostics reader and it isn't spitting out any codes. Anyone have this issue on F25???
Thanks!! " width="800" height="450" frameborder="0"> Last edited by ClampThurst; 11-19-2020 at 03:59 PM.. |
11-19-2020, 03:50 PM | #3 | |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
Could be your coils or spark plugs on the way out but if it's happening with the engine at temp only while stopped in gear, it's probably normal fluctuation due to electrical or other requirements. It doesn't appear to be erratic, looks pretty controlled from your second vid.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
11-19-2020, 03:57 PM | #4 | |
Rep 119
11-19-2020, 05:10 PM | #5 |
Rep 2,551
Which diagnostic reader did you use that you said it wasn't spitting out any codes?
11-20-2020, 03:38 AM | #6 | ||
Rep 888
11-20-2020, 04:20 PM | #7 |
Rep 119
11-20-2020, 04:22 PM | #8 |
Rep 119
11-20-2020, 05:03 PM | #9 | |
Rep 2,551
11-20-2020, 07:52 PM | #10 |
Rep 119
I also looked in the cars "hidden" menu(accessed by holding down the button on the dash for 20 seconds and then entering the sum of last 5 numbers of VIN to unlock) and it has a code section. There were no codes stored in there either.
11-20-2020, 08:51 PM | #11 |
Rep 2,551
I'm not sure if the hidden menu will show all stored codes. I'd recommend ista+.
11-21-2020, 03:31 AM | #12 | |
Rep 888
A proper reader is nerded
03-25-2021, 07:29 PM | #13 |
Rep 119
Had the car scanned at the dealer, No Codes!!!! Im surprised more people haven't noticed this...must not be normal I guess.
