09-11-2019, 08:50 AM | #1 |
Rep 22
Safest solution for Apple Carplay activation?
Hello friends,
I am also in the same situation as many others, in which my X3 doesn't have the wireless antenna installed (option code 6CP) and thus can't activate carplay via connecteddrive services. I am starting this thread in the hopes of getting up-to-date and confirmed solutions for activating Apple Carplay that could also help others in this situation. So far, based on my research it seems there are two types of activations, one via USB with a memory stick and the other more complex with an ENET cable and a laptop with an internet connection. They mostly depend on the software version of your navigation, but I am not sure exactly what the differences are. Are there also other methods? Secondly, it is quite unclear to me how safe these methods are. As with any coding there are risks associated and many things can go wrong (I have seen at least one case in the forums with a blue screen of death in the navi display). However, what I can't find and nobody can tell me for sure is what exactly happens when you take your car to the service for example for regular maintenance and they decide to upgrade the firmware (software). So far, I have read that with the update most likely carplay will be removed and additionally, one of these things might happen: 1. Can re-install carplay with the same method. 2. Can reinstall with an alternative method. 3. Cannot reinstall and you can say goodbye to carplay (permanent BMW fix) 4. Your navigation is bricked and you need a new head unit. Some people managed to get it fixed in warranty. Can anyone of the more knowledgeable guys shed some light into this? TL;DR: I want to install apple carplay on my BMW. What is the best and safest way to do this? Thanks! |
09-11-2019, 10:15 AM | #2 | |
Rep 2,046
Drives: X3 G01 30i xDrive
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
09-12-2019, 05:35 PM | #3 | |
Rep 90
I can't find any thread discussing those issues whatsoever, all I can find is general ideas about coding carplay but nothing too deep or detailed. |
09-13-2019, 03:36 AM | #4 | |
Straight Six Convert
444
Rep 894
Drives: 2019 X3 M40i
2019 G01 X3 /// M40i in Carbon Black, 718M 21's, M Sport + Pack, Pano, F/Mirrors, Full Screen CarPlay Activated, ThinkWare F770 F/R DashCams, Gyeon Q2 Pure Ceramic Coated. PCW BackBox Mod
09-18-2019, 03:53 AM | #5 |
Rep 37
Hi,
kubax86 activate Carplay for my X3 and it's working fine. He reply very fast to all my questions, activation was done less than half an hour after paiement and way cheaper than other methods, for the same results... The WIFI antenna is not needed as long as the phone stay on the cup holder. If you want to leave it in your pocket, you probably must install the antenna... |
09-18-2019, 11:23 AM | #6 | |
Rep 3,066
Thanks Like you said WiFi Antenna is not required, and sometimes it works just fine even in the pocket.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
Tags |
carplay |
