      04-24-2023, 03:50 PM   #1
evilchargerfan
evilchargerfan's Avatar
Drives: 2012 F25 (N55), 2014 I01 (REX)
Post Rear Camber Arm - Group Buy?
I wanted to see if anyone else out there is in the same boat that I am in, and in need of rear camber arms.
I have excessive negative rear camber, and found something that should solve my problem:
https://www.tatechnix.de/tatechnix/g...25-x4-f26.html
TA Technix lower traction bar set with camber adjustment rear axle fits BMW X3 (F25), X4 (F26)
PN 69BM003P
The item itself is affordable, but shipping to the usa make it really pricey. If anyone else is interested, maybe we can get a little group buy going and we can split the costs?
1 = 434.11 EUR to USD $479.50
2 = 583.11 EUR to USD $644.07
3 = 732.11 EUR to USD $808.65
      04-24-2023, 03:51 PM   #2
evilchargerfan
My numbers from a local alignment shop
The car in question, that is in need:
      04-24-2023, 03:53 PM   #3
evilchargerfan
More info, for those who care for it:
https://www.tatechnix.de/tatechnix/g...0_F25-f25.html
DESCRIPTION:
TA Technix wishbone set rear axle adjustable for camber adjustment
Mounting location between wheel carrier and rear axle carrier
1 set = 2 pieces
suitable for:
BMW X3 Type F25
Year of manufacture 2011 - 2017
BMW X4 type F26
Year of manufacture 2014 - 2018
Zulassung:
ohne ( im Bereich der STVZO nicht zulässig )
Hersteller:
passend für BMW
Modell:
X3, X4
Typ:
X3 Typ F25, X4 Typ F26
Baujahr:
2011 - 2018
Achse:
Hinterachse-3-teilig verstellbar
Ausführung:
Abmaße zusammengedreht - Augenmitte zur Augenmitte = ca.260mm Abmaße auseinander gedreht - Augenmitte zur Augenmitte = ca.350mm Kontermutter: SW27 Kugelkopf Durchmesser:51mm Abmaße der Augenbefestigung: Buchse innen:14mm / außen: 24mm / Buchsenbreite: 48mm Abmaße der Gabelbefestigung: Innendurchmesser: 52mm / Aufnahme Bohrung: 12mm / Gabeltiefe: 65mm
      05-25-2023, 05:16 PM   #4
Rising_Wave
Rising_Wave's Avatar
Drives: 2008 Jeep Commander Overland
$465 isn’t bad at all. 🤷*♂️
