06-25-2018, 07:36 PM | #1 |
Rep 396
Carbon Cleaning
Has anyone done this ?
I've booked my appointment for next Wednesday as im about 112,000 KM My mechanic says N55 should be done about every 100,000 KM Will see the end result. |
06-26-2018, 12:16 PM | #6 |
Rep 268
this is done on an installed head ? (active vehicle) curious
2017 BMW X3 x28i SOLD
2015 Honda CRV-EXL AWD 2019 Honda CRV-Touring AWD 1965 Chevrolet Corvette 327 / 4spd Convt |
06-27-2018, 08:28 AM | #7 |
Rep 3,550
Yes. That's one of the reasons for the walnut shells, tough enough to do the job but not so tough as to ruin an engine if some escape through the valves.
FWIW I will suggest it be used to solve a problem, if there is a problem, but not be done if things are running great. Some crap on the valves, as long as the seats are good and there's not so much build-up as to cause pre-ignition or anything, can be just fine. |
06-27-2018, 09:48 AM | #8 |
Rep 390
06-29-2018, 07:15 AM | #9 |
Rep 396
07-04-2018, 06:00 PM | #11 |
Rep 396
Not sure youw ould have to ask.
I just got my vehicle back, did the coolant expansion tank change & the valve cap as it was leaking as well as the carbon cleaning. Jeez, i took it out of the parking lot and was just slowing accelerating, i had to actually check if car was in sport mode. What a response difference!!! Mind you mine wasn't that bad, but still here are the before afters. Before: After: |
WagonR293.00 |
07-05-2018, 05:26 AM | #14 |
Rep 2,339
Sorry for the confusion alpwhite46. I meant what brand of gasoline. Specifically, do you consistently use Shell (as BMW recommends) or another top tier fuel?
What do I know? I'm insane.
07-05-2018, 12:44 PM | #15 | |
Rep 360
Not that there aren't other reasons to use a top tier fuel...I just didn't think it did much to help with this problem.
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
07-05-2018, 04:08 PM | #17 |
Rep 396
