03-25-2013, 04:26 PM | #1 |
Inspector Gadget
17
Rep 202
Winter Wheels 530d to X3
I currently have an F11 MY11 530d Touring and have a set of 17" winter wheels & tyres to replace the standard 19" set when its cold...
Does anyone know if these will fit the X3 i have on order? Fingers crossed they might...! Thanks
MY14 X3 35d M-Sport. Born 19/04/13, Delivered 31/05/13. Alpine White, Red Brown Leather, Brushed Aluminium, 19" 369 Alloys, BMW Media - Professional, Visibility Package, Access Package, Electric Seats w/ Lumbar, Variable Damper Control, Panoramic Roof, Extended Storage, HUD & Black Panel Dash, DAB, Reversing Camera & Top View, Heated Steering Wheel, Heated Rear Seats, Apps, Internet, BMW Loudspeaker Professional... & More.
03-26-2013, 02:10 PM | #2 |
Inspector Gadget
17
Rep 202
No-one knows then...
The specs on the wheel fitments are as follows: Vehicle Details - BMW 5 Series F11 Make : BMW Model : 5 Series F11 Technical Data; Production Year : 10 on - 2010, 2011, 2012, 2013 Pitch Circle Diamter (PCD) : 5x120mm or Bolt Pattern : 5x4.72inches Wheel Offset : 15 to 30mm Wheel Hub Center Bore : 72.6mm Wheel Fittings : B 14x125mm Vehicle Details - BMW X3 Series F25 Make : BMW Model : X3 Series F25 Technical Data; Production Year : 10 on - 2010, 2011, 2012, 2013 Pitch Circle Diamter (PCD) : 5x120mm or Bolt Pattern : 5x4.72inches Wheel Offset : 30 to 50mm Wheel Hub Center Bore : 72.6mm Wheel Fittings : mm The only thing different seems to be the offset - but have no idea if this would matter for a set of winters? Ta...
03-26-2013, 03:42 PM | #4 |
Inspector Gadget
17
Rep 202
Thanks for the reply...
After much searching for specs online that would tell me the brake disc sizes, I see that on ultimatespecs.com it lists the following: BMW F25 X3 xDrive35d Front Brakes - Disc dimensions : Vented Discs (328 mm) Rear Brakes - Dics dimensions : Vented Discs (330 mm) BMW F11 5 Series Touring 530d Aut Front Brakes - Disc dimensions : Vented Discs (348 mm) Rear Brakes - Dics dimensions : Vented Discs (330 mm) So appears that the F25 X335DM will have smaller front brakes (discs, at least) than my F11 530dM, and the same on the rear... if the figures online are correct. The 17's fit on my 5 series, so will fit over the brake discs. Waiting for an email from my dealer re specs, so when he gets back to me i'll ask him to confirm. Would a different "offset" necessarily be an issue?
03-27-2013, 09:46 AM | #5 |
Rep 292
I have no real technical knowledge but I would have thought this would be the inital issue especially for the front when steering.
According to the Tire Rack: Offset The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).* Zero Offset The hub mounting surface is even with the centerline of the wheel. Positive The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. Negative The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset. If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
