      05-28-2013, 02:00 PM   #1
jeschiotz
Drives: BMW X3
Pirelli p Zero Run Flat
I got my used car last year in August and they where fitted with the mentioned Pirelli 245/50 r18. I thought the car managed alright at the time. During wintertime I switched to Nokia wintertires on my 17 inch . I got my summertires on again and noticed a big difference in handling. The Pirellis is just plain awfull ! The car need to be steered all the time and hitting a bump makes the car go all over the place. It just follow every line on the (bad) road.
Now,I start to read about this and it seems that the run flat could be the problem. I came across one site that explains that BMW has been set up with run flats and if you want to use ordinary tires you need to tune the suspension.
Is this really correct? If so,why does the car handle better on my winter tires?
I came to the conclusion that I want ordinary tires ,but what to choose? Any suggestion? I have looked at the GY Efficientgrip SUV
      05-28-2013, 02:19 PM   #2
The X Men
Drives: 2013 X3 35i
Maybe your winter tires rides better because they are new or your Pirelli might be defective. Runflats do not make your car handle better or worst, but it can make the ride a bit stiffer. You do not need to re-tune your suspension if you switch to non-runflats, you didnt do it for the winter tires right? If you want to switch to non-runflats the Michelin Primacy is a good choice.
      05-28-2013, 02:29 PM   #3
NordicBMW
NordicBMW's Avatar
Norway
Drives: 2012 X3 / 2013 X1
I experienced exactly the same when switching from non-rft 17" winter to my rft 18" summer. But after a few days I got used to it and now I hardly notice. But I'll replace the rfts with regular tyres when they are worn out.
      05-29-2013, 05:22 AM   #4
Nahoa
I have no problems with mine, including switching from winters (Pirelli Sotto Zero).
      05-29-2013, 12:23 PM   #5
DonC
Drives: 2013 X3 3.5i M sport, etc
I notice a difference when I switched from the OEM 18 in winter tires to the OEM 19 in wheels and RFTs. I plan to switch to Michelin SS later this summer or early fall.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
      05-30-2013, 03:30 AM   #6
jeschiotz
Drives: BMW X3
http://www.wheels-inmotion.co.uk/bmw...t-problems.php
      05-30-2013, 10:03 PM   #7
tango131
Drives: Boxster S; 2013 X3 28i
Michelin mxm4 are excellent all season tires. See tire rack.com for reviews.
2013 X3 28i, AW, Chestnut, Sienna, ZAP, ZCV, ZCW, ZDH, ZPP, rear view, park distance, cargo net (Wife's) (Pics and story)
2010 Porsche Boxster S (Mine)
      06-01-2013, 08:42 PM   #8
ozbmwx3
Australia
Drives: bmw x3
Can I mix RFTs and non-RFTs on the same axle? Eg, use a non-RFT as a spare.
      06-01-2013, 11:09 PM   #9
brissim
Drives: X3 30d (2011 F25) - now sold
I know tyre manufacturers do not recommend it. I suspect a reason is probably something to do with differences in unsprung weights on either end of the same axle causing problems for the cars electronics or whatever.
Tony
      06-03-2013, 03:25 AM   #10
jeschiotz
Drives: BMW X3
Since I have special dedicated wintertres I dont want all seasontires.
Any other suggestion?
      06-03-2013, 04:54 AM   #11
mcmasman
Norway
Drives: '12 BMW X3 2.0D msport
My 2012 model came with 19" Pirelli P-Zero run flat, 245 front and 275 rear, there is an insane amount of grip. My personal preference is a more sporty , stiff ride so i have no issues with it, coming from a Audi A3 S-line 18" setup.
I have not use my 19" winter set yet (Nokian Hakka R2, 245 all corners), but assume they will be more comfortable due to the softer compound.
I noticed from time to time the steering wheel pull slightly to one side, while seemingly the road was flat (somewhat flat), on the highway where it is truly flat I have not observed the same.
It would be interesting to see if this behavior will be the same with winter tires.
