01-15-2015, 08:58 AM | #1 |
Rep 132
Any one feels the tranmission is too busy & jerky at low speed?
I have a 2014 35i and in slow or stop and go traffic the SUV is both laggy and jerky.
Way too many shifts from the transmission. Some of the downshifts are decidely unessecery, especially with the massive torque of the N55 engine. The transmission should be programmed to ride the awesome low-end torque of the N55. But instead it always like to downshift prematurely, as if it is mated to a tiny revvy 4 cylinder. Maybe BMW used the same transmission calibration for all the gas engines? |
01-15-2015, 11:58 AM | #3 | |
Rep 132
But when caught up in city traffic for extended period, the transmission seem to revert back to the "jerky mode". |
01-15-2015, 01:31 PM | #4 |
SPEED RACER
375
Rep 740
That's strange. Do you have the sport transmission or standard?
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black |
01-15-2015, 02:01 PM | #5 | |
Admiral
Rep 48
Once on the move I could not fault it. |
01-15-2015, 02:32 PM | #6 | |
Rep 236
01-15-2015, 03:05 PM | #7 | |
Rep 132
Your 2.0D is a diesel right? it should have lot of torque. I found the tranmission programming generally prefer to "rev" instead of using "torque". Which is quite odd given how much focus is put on MPG nowadays. |
01-15-2015, 03:09 PM | #8 |
Rep 132
Yeah, this kind of thing doesn't show up unless you are caught in creeping/stop and go traffic for extended time. Once it gets up to speed it is all good.
I have the standard transmission, but I assume the shifting should be the same under the normal mode? Sport ones has paddles and faster shifts only under sport+ mode? |
01-16-2015, 03:07 AM | #9 |
Rep 560
I have the 20D and find that I don't like the shift change in stop-start traffic. I had the programming of the gearbox checked out by BMW as I thought it was faulty, but they said it was fine. What I now do in traffic, is shift manually and then I have exactly the right gear for the conditions. I enjoy driving my car a lot more since making this change!
01-16-2015, 04:19 AM | #10 | |
Air Vice Marshall
256
Rep 1,639
I find if I use it in Sport Mode it really is fine. It is away from the traffic lights like a scalded cat. If that is what I want to do. If I leave it in Comfort Mode with a small amount of throttle it is really smooth and with my wife as a passenger says she hardly feels like it is changing gear. I cannot help thinking the UK 2.0d (old and new engine) is working differently (more gear changes) to keep itself in the optimum tighter rev range for economy, whereas with the larger 3.0d this is not so critical. Anyway with 8 gears this is going to happen more often than with the older auto gearboxes on previous cars. That is my view anyway. |
01-16-2015, 04:38 AM | #11 | |
Rep 236
01-16-2015, 06:04 AM | #12 |
Rep 2,527
I find the 8sp on mine pretty well adapted. If there are two drivers in the car make sure you use separate keys and driver profiles. That would ensure the shift adaptations are tailored to your style.
That being said, I never really feel shifts or hunting on this very smooth transmission. Only under light throttle I notice the car "asleep " and I need to be more assertive to get it moving.. either a shift to DS or toggle to Sport will do the trick. On my dad's 2011 I find I gotta drive it for awhile before it sorts itself our as there are four drivers on that end. |
01-16-2015, 07:37 AM | #13 |
Rep 2,323
If you want it to hold a gear longer, use the sport mode. There is a software update for jerky transmission at low speed, talk to your dealer about it.
01-16-2015, 08:46 AM | #14 | |
Rep 198
In the first 3 weeks of the car it was always in city traffic so I had the same objervations as well. Had to push it to go types. However I was taking it slow since I was in the runnin period. I am now on a 900KM road trip and trying 150-160km/l and it's just like butter - effort less and happy to go more but I am restricting myself till I clock 2000km as per the manual. The bright side is when I am now at my destination, I see the normal city driving is also much smoother like the car understood what I like and working to it. But after reading this thread it looks like when I go to my normal office life with being greeted with stop and go traffic, things will become sluggish again?? |
01-16-2015, 10:03 AM | #15 |
Nuclear Chief of the Watch
120
Rep 637
Manage to avoid most city driving issues - but do find in slow moving ( rather than stop start ) traffic that pushing it into sports mode does the trick.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
01-16-2015, 11:59 AM | #16 | |
Admiral
Rep 48
Also I will try the Sport mode as suggested, and play around with Manual shifting. I will report back. |
01-16-2015, 09:22 PM | #17 |
Rep 253
I wish I had known about this a week ago when I went in for my first scheduled service.
I first noticed this when on a trip out of town when I took my father along. I've had car problems before when on vacation, and it would be worse on a road trip in a new car. Something just didn't seem right. I finally decided that it was just me being more aware, because I was away. But this thread indicated the other reason. I was probably being more careful with acceleration, which makes the shifting more apparent. And I was normally using Eco Pro mode on this trip. |
01-17-2015, 04:26 AM | #18 | |
Rep 560
01-20-2015, 01:41 PM | #19 | |
Rep 129
01-20-2015, 02:24 PM | #20 |
Rep 132
I felt that too. The first gear is way too short (at least for the large engine on x3 35i or 35d), almost like i am free reving the engine At 25% to 50% throttle, I get much better acceleration from 2nd gear.
01-20-2015, 02:33 PM | #21 | |
Rep 132
Actually either sport and eco mode helped: sports mode holds a gear longer, eco mode prevents premature downshifts. The comfort mode is the least comfortable of all under stop and go traffic. |
01-20-2015, 06:25 PM | #22 |
Rep 49
I too find 1st gear to be a little short on my 35i. Sooo much smoother when I manually take off from 2nd. I wish there were a way to lock out 1st gear without having to shift manually.
2007 E90 335i -> 2007 E70 X5 4.8i -> 2012 F25 X3 35i -> 2016 F30 340i
