      12-27-2013, 03:20 AM   #1
ianfp
ianfp's Avatar
Drives: X5 40D M Sport
Parking Windscreen Wipers
Hi everyone, I hope you are all having a good festive season?
I want to change my wiper blades, but try as I might, I cannot get the wipers to park in the vertical position!
I have read the manual and think I am doing the right thing i.e. with the ignition off, move the wiper stalk fully up and hold for a few seconds.
I have tried all different variations, but still the wipers do not move.
Can anyone help please?
Thank you!
      12-27-2013, 04:32 AM   #2
cooldude00
Drives: x3 2.0d
have you tried just moving the wipers when the ignition is off? cos i move mine to clean the car/windscreen and have no problems doing so? it moves by about 45 deg upwards and that's more than enough to change the wipers?
it's here!!!
      12-27-2013, 04:36 AM   #3
ianfp
ianfp's Avatar
Hi cooldude, no I haven't tried that, but I will try to carefully move them. Thanks for the tip! Still mystified as to why they don't go vertical as they should!
      12-27-2013, 08:16 AM   #4
philtrick123
Drives: TBA
Forum search is your friend....
http://x3.xbimmers.com/forums/showth...ht=park+wipers
      12-27-2013, 09:11 AM   #5
ianfp
ianfp's Avatar
Hi philtrick, I have seen that thread and read the manual carefully, but it just doesn't work!
      12-27-2013, 09:37 AM   #6
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
The ignition must be switched off. And the door should be opened and closed. It doesn't seem to work if you drive the car, park, then immediately try to put the wipers in service position.
      12-27-2013, 09:46 AM   #7
Booty
Enjoying it!
Drives: X3 3.0D M
Start engine, stop engine then try with door closed mate. Worked for me!
      12-27-2013, 10:07 AM   #8
ianfp
ianfp's Avatar
Booty, you're a star! This worked exactly as you said. I had been trying this with the door open and it didn't work. I thought it was going to be a trip to BMW, but thankfully you have saved me the trouble! Cheers!
