      08-10-2011, 01:11 PM   #1
96_Impreza
96_Impreza's Avatar
12
Drives: 96 Impreza,07 Vette,11 X3 35i
What means "28" & "35", if anything?
We just ordered our first BMW, a white 2011 X3 35i, and while there learned that the 28's displacement is 2996 cc and the 35's is 2979.
So, what do the "28" and "35" mean, if anything?
      08-10-2011, 01:28 PM   #2
rest0r
rest0r's Avatar
Drives: 2008 535i
I've also wondered this and apparently there is no technical reason for the name. It just indicates an improvement over the 2006 '25' and '30' models.
      08-10-2011, 01:35 PM   #3
Red Bread
Drives: Smog machines
They simply reflect that BMW and Mercedes think their buyers are too stupid to understand what a "t" means. Way back when, the last two numbers of any BMW indicated engine displacement. Then it got confusing with turbos, so they tried to approximate the equivalent naturally aspirated engine required for similar stats. So a turbo (single or double) 3.0 liter became a 3.5 in BMW Marketing Land.
Unless you buy a 6er or 7er, where a turbo 3.0 liter gets another half liter of fake displacement to become a 4.0 liter.
Prior to the advent of turbos, the two motors were a 2.8 liter and a 3.0 liter, so as not to confuse the idiots, they chose to retain the 2.8 moniker even while increasing displacement to a true 3.0 liters. In the near future, a 2.0 liter turbo four cylinder will retain the 2.8 name. Make sense?
      08-10-2011, 01:54 PM   #4
96_Impreza
96_Impreza's Avatar
12
Thank you, Red Bread.
"Equivalent" displacement I understand. I had no luck finding meaning for 28 and 35 in vehicle specs. Not even beverage cup holder capacity or oil dipstick length were matching 28 & 35.
      08-10-2011, 03:33 PM   #5
Lotus7
Drives: xxxx
If you find a spec. for the oil dipstick length for a 28i or a 35i, please publish it. The oil dipstick specs. for the 28i and 35i are a high-level trade secret at BMW. You need a BMW "Level-5" security clearance plus knowing the secret handshake, to even be told the dipstick location on these engines. Owners and typical service advisers are not given the dipstick location information at all. Just check the X3 owners manual under checking oil level, and you will find no mention of the existence of a "dipstick".
      08-10-2011, 03:40 PM   #6
tagz
tagz's Avatar
Drives: 2011 BMW X3 xDrive 35i
+1
Impressed by the wealth of information you have Lotus7
      08-10-2011, 04:27 PM   #7
tuco44
tuco44's Avatar
Drives: 2018 340i xDrive M Perf Edtn
Originally Posted by tagz View Post
+1
And wit.....
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971.
      08-10-2011, 04:34 PM   #8
Beyu
Drives: 135i
Originally Posted by tuco44 View Post
And wit.....
Mostly wit for this one lol. Isn't it a sensor instead of a dipstick?
      08-10-2011, 05:31 PM   #9
jsublime
Drives: G20 M340i
2015 BMW X3 28i  [0.00]
2011 BMW 135i  [0.00]
2016 BMW M3  [0.00]
Good thread
It didn't just start with the turbos though, I have a 325 that has 3.0L.
      08-10-2011, 05:33 PM   #10
XRP
XRP's Avatar
Drives: X3
interesting....
      08-10-2011, 05:39 PM   #11
dandanio
The one that drives!
dandanio's Avatar
Drives: 11 x3 35i/09 Jetta TDI
All 3 liter in-line 6s are:
-25, -28, -30, -35 and -40.
First 3 models are naturally aspirated, -35 and -40 are turbo'ed.
It only means that -25 is less powerful than the -28, which in turn is less powerful than the -30.
The difference is mostly in engine tuning and materials. Also, -30 had a different fuel pump (3-stage) and some other tweaks.
-35s and -40s are turbo'ed, N54 or N55 engines, just a matter of tuning (boost and ECU programming).
Oh, and now... the best part, all future -28s (and some current ones like in 5-series and Z4) are 2.0L in-line 4 turbo'ed cranking out more ponies and ft-lbs'es than the current in-line 6 -28s.
Hope that confuses you even more...
[d]
      08-10-2011, 06:04 PM   #12
raleedy
Drives: 2016 228i 6-speed
28 = 3.0 L
35 = 3.0 L
Clear now?
      08-10-2011, 11:16 PM   #13
Lotus7
Drives: xxxx
+1
My "wealth of information" is worth about as much as the gains in the DJIA this week.
As you know, if it's published on-line, it must all be true.
      08-10-2011, 11:58 PM   #14
sparoz
sparoz's Avatar
Australia
191
Drives: VO 1///M; Macan Turbo
Except the N20 F10 5er in Australia is going to be the 520i. The 125i with the 3 litre N52 engine same as the 128i in the US. While I believe the 325i retained the old 2.5 litre inline 6. The 7er 40i actually had the updated N54 with better cooling to produce 245kw. While the same engine in the 3er is a 335is . I guess it does get confusing with the old Audi speak and trying to explain why the 1.8T is more expensive than the 2.0. So, I don' think equivalent displacement really make sense - it is more like marketing speak.
Macan S Diesel - Carrera White
Macan Turbo - White
1///M - Valencia Orange
      08-11-2011, 07:54 AM   #15
tagz
tagz's Avatar
Now, this is wit
      08-11-2011, 05:08 PM   #16
TuffLittleUnit
Drives: G26 420d MSport Pro
It works both ways. The 318d loaner I have whilst waiting for my X3 is actually a 2 litre diesel but most people (including me before I received it) think it's a 1.8l engine. Still, I'm not complaining when it gives me 55mpg on long motorway trips (note this is UK gallons)
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
