      01-23-2017, 12:04 AM   #1
SimplySpoons
Drives: 2017 F25 X3 xLine
Best touch-up paint
So I've discovered the tiniest most minuscule paint chip on the hood of my X3. Brand new car, and a rock decided to have its way with the paint It just looks like a tiny speck of dirt, and it's only unnoticeable unless you know it's there, but I'd like to get some touch-up paint for it. What would you recommend for touch-up paint? I know BMW makes their own, and I've seen some other options as well. The car is Deep Sea Blue Metallic. Any input would be much appreciated!
Thank you!
      01-23-2017, 09:09 AM   #2
momoboy
Drives: F15 35i 2017
Dr. Colorchip. Best/easiest I have every used.
      01-23-2017, 11:38 AM   #3
SimplySpoons
That looks good! Thank you!
Which kit would you recommend? https://www.drcolorchip.com/select-product.php
      01-23-2017, 02:00 PM   #4
momoboy
Just get the Standard Touch-Up Paint Kit. It's all you will need to touch up the chips. It's super easy and looks great. Just follow the instructions. You will be happy!
      01-23-2017, 02:05 PM   #5
SimplySpoons
Will do, thanks again!
      01-23-2017, 03:20 PM   #6
Peter_R
Air Vice Marshall
Peter_R's Avatar
Most of the time using the little brush that comes with kit leaves too much paint in a very small chip hole.
From experience I have found that a cutting a match stick down to a point and using it to drop a small droplet into the hole works well. Naturally using a large blob of paint is undesirable.
Perhaps a small amount on a toothpick will do.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      01-26-2017, 07:33 PM   #7
malicem3
Drives: 2022 X3
Tooth pick is what I use.
