      08-05-2016, 11:07 AM   #1
smckenna
Drives: 2013 BMW M3
2017 X3 xDrive35i paddle shifter questions...
Q1: When using the steering wheel paddle shifters to shift, should I momentarily left off the gas slightly while shifting, or is it OK just to keep the pedal to the medal while shifting?
Q2: Which is faster 0 to 60, someone paddle shifting this car model, or letting the automatic transmission take care of things?
      08-05-2016, 01:21 PM   #2
epiphone3
Drives: 2013 BMW X3 35i
Q1: full throttle and don't lift off. The computer takes care of everything.
Q2: Good question... if you let the Auto do its thing, it runs the engine speed up to 7000 rpm but the horsepower starts to fall off after 6,400 rpm. I think someone using the paddles and shifting at 6,400 would be fastest but I have no instrumented test to prove it.
      08-05-2016, 01:23 PM   #3
smckenna
Drives: 2013 BMW M3
Thanks for the info. Very informative.
      08-05-2016, 01:28 PM   #4
bichoo
bichoo's Avatar
Drives: BMW X5 40i M-Sport
If you compare it, make sure in Auto, you use Launch Control
      08-05-2016, 01:30 PM   #5
smckenna
Drives: 2013 BMW M3
Thanks. I'm definitely going to wait until my break-in has been completed for that trick.
