      08-02-2016, 06:57 AM   #1
Steady Eddy
Drives: X3 MSport 30D
Software Update
Newbie here and first time BMW owner! First post so hope you can help!
Just trying to sort out if I have the latest software installed. The following is a pic. of my iDrive screen:
When I put my VIN in the update site it gives an update file which as far as I can make out contains lower versions beginning MN-002 where mine is at MN-003.
Am I correct and have I got the latest installed/
Thanks
      08-02-2016, 07:37 AM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
The short and only answer is YES.
I carried out a similar exercise with the BMW Tech at my local garage.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      08-02-2016, 08:00 AM   #3
Steady Eddy
Hi Peter,
many thanks for the quick reply. That is what I thought.
Pity the website doesn't give a straight answer!
Enjoying the 30d very much though !
      08-08-2016, 12:18 PM   #4
Dracon
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
The website only shows the latest version approved by BMW for owner-install, they are usually several versions behind the ISTA/P (dealer-install) versions.
There are newer versions that are built into ISTA/P and installed when the rest of the vehicle firmware is updated. That's probably the case with your vehicle, it was updated by a dealership with ISTA/P and the newer version in ISTA/P was installed than what's approved for owner-installation via the website.
