03-26-2019, 05:43 PM | #1 |
Rep 40
Cleaning vinyl seats
Does anyone know the best cleaner or way to clean the sensitec seats? I need to get some light stains out of one of them, and I'm not sure the best product to use. I've read that Mr clean erasers work, but I'm afraid it might remove the color also. Any suggestions?
03-26-2019, 07:25 PM | #2 |
Rep 1,906
Magic eraser from what I've heard is bit too aggressive.
I think a mild detergent and water- if that does not work effectively then ask an upholstery shop; bet they can steer you to appropriate product/method. |
03-26-2019, 07:38 PM | #3 |
Rep 120
I've used Mr. Clean Magic Eraser on both leather and vinyl and it's worked well. In each case surface grime and body oils were being removed, not stains that had penetrated the upholstery. The key is to do a small test area using plain water without being overly aggressive. If the test area proves satisfactory then expand to a larger area and work until you get the desired result. Go slow as it may take several passes.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
