      05-14-2016, 02:34 PM   #1
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Fuse Box Behind Glovebox Made Easy
Blew #54, 20amp fuse when i dropped a lightening cable in the outlet. I could get my big paw through the access in the glovebox and then use the braille method to pull the fuse with provided fuse puller. Putting the replacement in was a different story. I dropped the first two and the third one just wouldn't go in.
Here's the tip. Leave the access open and use for flashlight/torch lighting and sighting. Remove the three torx screws(T-20) of the cosmetic panel towards the rear of the bottom of the glovebox and pull down. You now have easy access to the fuses and sight through the access area. Ten minutes in and out.
