      12-18-2014, 12:41 PM   #1
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
Question battery charging?
My ctek battery tester indicates a weak/bad battery. Does anyone know if I should recharge directly to the battery in the trunk or from the hood's terminal post?
Also, if battery is bad and can no longer hold a charge, any thoughts on duralast or interstate battery H8?
thanks
      12-18-2014, 12:49 PM   #2
Want the thrill
2022 X4M40i  [10.00]
Charge it from the front terminal post.
      12-18-2014, 02:01 PM   #3
Pitiful Old Man
Drives: 2011 X3 35i
If you're still in the warranty period, your dealer should replace the battery for $0.
Confirm that the CTEK connection via the posts in the engine compartment is correct. I use a CTEK fairly often, just to maintain the battery when the car is idle for days at a time. I think that the BMW supplied battery is a pretty good one. You may have just been unlucky.
      12-18-2014, 02:20 PM   #4
ejw2011
ejw2011's Avatar
94
I did check the connections and made sure it registered on the ctek. Tested both at the terminal post and directly at the battery. Only have 6 months before warranty is up, but my understanding is BMW does not consider a battery under warranty but as maintenance to recharge.
      12-19-2014, 02:19 PM   #5
Pitiful Old Man
Drives: 2011 X3 35i
If it's a defective battery, they should replace it. A good dealer will do this and check the charging system for you at no cost. A somewhat less than good dealer may want to pro-rate it based on the battery warranty. A bad dealer will charge you for a new battery.
      02-10-2015, 08:07 PM   #6
pprevill
Drives: 2013 X3 CB
Ctek battery charger
Did you do a permanent connection with confort cable to charge your battery ? I'm looking for an easy solution to hook a ctek charger to the charging post in the hood of my x3 but don't know if the ctek cable will fits ? They seem to have 3 options on their web site :
Choose M6 for smaller batteries like motorcycle/lawn tractor.
Choose M8 for top post batteries.
Choose M10 for side post batteries.
Someone has already hook one of these ?
Also did you use 'cold mode' type charging ? Seems to be best for agm batery but not so clear since not all battery vendor listed ?
Thank you !
      02-12-2015, 10:46 AM   #7
Peter_R
Air Vice Marshall
Peter_R's Avatar
pprevill
You posted the above similar question twice. The complete answer is in the following thread...
http://x3.xbimmers.com/forums/showthread.php?t=1090356
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
