04-19-2024, 03:47 PM | #1 |
Rep 33
Drives: BMW X3 M40
X3M continued driving possible:chassis
Hey guys. Was on a long drive and continued driving possible: chassis popped up. Put it into limp mode and I can’t use any of the M modes and the mode for the suspension on the odometer is blank. Pulled the code and it’s coming up at 1F052F. Acceleration Controller Intervention. Anyone else have this? I am tuned on BM3 OTS E30 stage 1 and lowered on H&R suspension.
04-19-2024, 05:30 PM | #2 |
DINAN SELLER
179
Rep 555
2024 X3M COMP, 2019 X3 M40i DINAN, 2015 335xi DINAN stage 4, 2014 BMW i8, 2010 M5 V10 DINAN S2
04-19-2024, 05:32 PM | #3 |
Rep 33
Drives: BMW X3 M40
Yes. Please read my original post. You may have missed that part.
04-19-2024, 07:55 PM | #4 |
DINAN SELLER
179
Rep 555
I have seen this issue with the e30 and e50 tunes. Can you revert to stock and confirm if errors is resolved?
thestimp982.50 |
04-19-2024, 08:07 PM | #5 |
Rep 33
Drives: BMW X3 M40
I’ll try that and see what happens. Thanks!
Dinan_Rated178.50 |
04-20-2024, 11:14 AM | #6 |
DINAN SELLER
179
Rep 555
LMK thanks, good luck!
04-21-2024, 06:47 AM | #7 |
Rep 348
This is a suspension sensor issue. Get someone to run a diagnostics test, or do it yourself and you should see something similar to "open circuit front right suspension".
I had this issue come up after installing my Eibachs, turns out the front right sensor cable was kinked. You have to be very careful with those sensor cables.. the kinked was actually minimal but it's enough for the car to sensor "low voltage" on the cable. Goodluck. By the way you should be fine to drive however, you won't be able to change the suspension mode but all other settings should work. Last edited by knali8; 04-21-2024 at 06:52 AM.. |
04-24-2024, 10:05 AM | #9 | |
Rep 409
ASP |
