04-01-2024, 07:13 PM | #1 |
Rep 5
Wind Noise
I picked up my 2022 X3M Comp last fall. I have loved it except for the wind noise at highway speeds. I couldn’t locate the source, but while washing her this weekend I discovered a gap in the seal around the sunroof on the passenger side. It’s large enough I can put my finger in it. I have attached a pic. The drivers side gap is much smaller.
Has anyone had a similar issue? Was the dealer able to willing/ able to correct it? I will be making an appointment for a oil change in the next few weeks and want to know what to expect when I ask the dealer to look at it. Thanks |
04-02-2024, 07:27 AM | #3 |
Rep 495
I started to notice increasing noise from what sounded like the sunroof in November last year.
I have taken it into the dealer and they have confirmed that it is "not right" and it is booked in to be fully investigated and hopefully fixed next week. The only comment the technicican made was that "the X5 suffers with these seals as well," but am not sure what that ultiamtely means. I've checked my gaps and they are not as big as yours. The first picture is my driver's side, and the second is the passenger side. Mine is a UK spec car, so driver and passenger sides will be different. James.
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic Gone: 2018 F80 M3C - Sakhir II Orange Metallic Gone: 2015 F80 M3 - Mineral Grey Metallic |
X3MRon3.00 |
04-02-2024, 08:06 AM | #4 |
Rep 541
Drives: 2022 X3MC
Common issue... I've had mine replaced twice now under warranty.
There is a whole thread on this: https://x3.xbimmers.com/forums/showthread.php?t=2034267
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
X3MRon3.00 Mnfamilyguy2020130.00 |
04-02-2024, 11:33 AM | #6 |
Rep 439
04-02-2024, 12:43 PM | #7 |
Rep 10
Canadian humour.
Seinfeld Shrinkage episode. |
Th3Walrus340.50 Kevin_The_Clean13305.50 |
04-02-2024, 06:11 PM | #10 |
Rep 5
Thanks guys. I wasn’t sure if I would get any push back from the dealer.
04-03-2024, 03:11 PM | #11 |
Rep 188
Best thread.... After reading this I checked my pano and found (see pic 1)
https://x3.xbimmers.com/forums/attac...1&d=1712174478 After some research I found this Bulletin: https://static.nhtsa.gov/odi/tsbs/20...44239-0001.pdf Called my local dealer and because I'm under CPO they wanted an hour of labor to diagnose and were two weeks out. The part number for the seal is: 54-10-5-B32-973 The dealer price matched it at $46, and within 15 minutes I had it installed and the wind noise is SOOO much better and I'm sure it is much more water tight. I used BMW Gummi-Pflege Rubber Care - BMW (83-19-2-449-390) to lubricate the "track" the seal is mounted on and it slid right in place. I did apply two small beads of the adhesive to the seal per the bulletin. https://x3.xbimmers.com/forums/attac...1&d=1712175077 |
04-04-2024, 04:39 PM | #12 |
Rep 27
Glad this thread popped up. I have also been noticing wind noise the past couple weeks and swear it was never there before. I'll have to check my seals and report back after work.
Edit: Well there doesn't seem to be any sort of gap in that seal on my '23, so maybe it is coming from elsewhere, but I checked and really couldn't find anything. Maybe I'm going insane lol Last edited by BlauHouse; 04-05-2024 at 02:06 PM.. |
04-05-2024, 01:26 PM | #14 | |
Rep 188
04-05-2024, 02:01 PM | #16 | |
Rep 188
Th3Walrus340.50 |
04-05-2024, 06:06 PM | #17 | |
Need mo $$s
840
Rep 890
My 2020 has about an 1/8" gap on both sides, so will remove it, stretch it and then re-apply with the adhesive. Just curious, did yours have any adhesive on it when you removed the original one?
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 04-05-2024 at 06:12 PM.. |
04-05-2024, 10:30 PM | #21 |
Rep 339
Kevin_The_Clean13305.50 Y0jjimb0233.50 |
04-06-2024, 01:15 AM | #22 | |
Rep 3,942
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
95wildtt840.00 |
