      02-01-2018, 02:41 PM   #1
brunp
Drives: 2013 BMW X3, 1997 BMW M3
Replaced battery on Key Fob but warning still persists
Should the warning eventually go away? Do I need to clear a code on via OBD II?
Paul
      02-01-2018, 02:44 PM   #2
Aspen235
Drives: 2014 X3 35i, 2018 M240i 6mt
I had the warning lots when my comfort access on my E91 was failing. Changing the battery didn't help because it was a comfort access handle/module issue.
Is the comfort access working normally?
      02-01-2018, 03:02 PM   #3
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Hold the key fob next to the key decal on the steering column. That made mine go away and the comfort access started working again.
      02-01-2018, 03:07 PM   #4
brunp
I did have both front windows and regulators replaced with a new kit and the polarity on the switches is reversed. Need to get them flashed with right programming. Windows behaved irraddically when using handle to open door
      02-02-2018, 11:05 AM   #5
Aspen235
Comfort access is complex and seems to cause different issues. When my first door handle failed it caused a drain on the battery and eventually shut down the whole system. When the antenna failed it started giving key fob battery issues.
My car was from Montreal originally, I don't think the system likes cold winters or salt much.
      02-03-2018, 05:46 PM   #6
kevink1
Drives: 2015 X3 xDrive28d
I started getting the battery warning coincidencially when I was on vacation 12 days ago in Colorado, where it was cold. The same week I had several other warnings (camera system, due to frozen slush), low coolant, etc.
Luckily, replacing the battery when I returned home solved that problem.
The car's sensors don't seem to like cold weather.
