      03-06-2017, 07:35 AM   #1
FranzX3M
Drives: '13 X3M
2013 x3 35i wants to stall on cold mornings
When I start my 2013 X3 M sport 35i on cold mornings, below freezing, it starts fine but then immediately begins to choke and almost stall, then perks up after a 3-4 seconds and seems fine. This morning seemed particularly bad but there have been much colder mornings. Any thoughts on what could be causing this? I know most cars have a cold start mode to adjust idle and other parameters but these newer cars probably have a lot more inputs to this.
      03-06-2017, 11:33 AM   #2
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
There are many things that may contribute to your X3 running poorly after cold starts in cold weather: for example, spark plugs and/or ignition coils may need to be serviced, fuel injectors may need to cleaned or replaced, there may be a small vacuum leak, air intake system may need to be serviced or a combination of these problems. Are you getting any codes?
https://shadetreespeedshop.com/my-ca...orly-cold-why/
      03-07-2017, 05:42 AM   #3
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Mass air flow sensor could be the culprit as well
      11-02-2017, 08:17 PM   #4
FranzX3M
Drives: '13 X3M
Well the weather is getting colder and this issue is starting again. It has 82k kms. There are no check engine lights. It only lasts for a few seconds and then its all good. I wonder if throttle body should be cleaned. Could be a partially blocked port?
