01-08-2024, 01:38 PM | #1 |
Rep 36
Car was shot overnight
Going to get this repaired at a collision center this week. Does anyone know if this fix will require a new door skin?
01-08-2024, 01:41 PM | #2 |
10857
Rep 27,629
holy smokes!
do you know what happened? any more context ?
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-08-2024, 01:45 PM | #3 |
Rep 492
Drives: 2009 E93 M3 DCT
'Merica
17
chris7197375.50 TonyB5840.50 tranquility3291.50 Polo088161614.50 KevinGS3377.00 G35POPPEDMYCHERRY4998.50 spielnicht440.50 chetrickerman10446.50 a5m618.00 nearwater4me1918.50 LogicalApex2030.00 co_440i114.00 zero2sixtyZ952.50 SkykingUSA1434.50 slowblackx3f2573.00 tsk941526.00 houbmw65.50 |
01-08-2024, 01:50 PM | #4 |
You got my money?
3225
Rep 4,704
Drives: Ice Cream Truck
Bondo and respray most likely.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
01-08-2024, 01:54 PM | #5 |
Rep 6,328
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
this. Any damage to any components that you know of?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
01-08-2024, 02:01 PM | #6 |
Rep 6,312
Florida man at it again
What does it look like from the inside? |
01-08-2024, 02:46 PM | #8 |
Rep 659
Tell us the truth and the details about the road rage....
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
slowblackx3f2573.00 |
01-08-2024, 02:47 PM | #9 |
Rep 10,672
Someone was exercising their constitutional right to bear arms….
TonyB5840.50 slowblackx3f2573.00 |
01-08-2024, 02:59 PM | #10 |
Rep 783
I'm not sure I would fix it, it's kinda cool. Stick an ear plug in there to keep the water out on a rainy day.
2008 E86 M coupe
01-08-2024, 03:13 PM | #11 | |
Rep 1,966
Drives: 2020 BMW M4 CS
I doubt you will get a new door skin and if it was my car I wouldn't want one as any trained eye can generally detect a reskined door. I would demand a welded metal repair and not a Bondo job. This will require stripping the door due to welding They should cut out the damage and weld a plug in completely, followed by metal finishing. Good luck. |
01-08-2024, 03:36 PM | #12 |
Rep 36
No clue what happened. Pretty much I walked out of my apartment complex and noticed a bullet impact. Called law enforcement for my insurance and got a case number. The officer and I tried to look for the bullet head or casing but no luck. But technically the bullet could still be inside my door. Hopefully, I wasn't being targeted or anything lmao.
GOLFFRR10856.50 Murf the Surf19216.00 DrFerry6731.50 StradaRedlands4997.00 SkykingUSA1434.50 slowblackx3f2573.00 |
01-08-2024, 03:38 PM | #13 |
Rep 36
01-08-2024, 03:42 PM | #14 |
Rep 36
01-08-2024, 03:44 PM | #15 | |
Rep 36
Car-Addicted7239.00 Polo088161614.50 |
01-08-2024, 04:17 PM | #17 | |
10857
Rep 27,629
01-08-2024, 04:29 PM | #18 |
Rep 1,135
Drives: G30 M550i
01-08-2024, 04:36 PM | #19 |
Rep 212
If the door is aluminum, it needs to be replaced. If it's steel and the intrusion beam hasn't been hit, technically it can be folded back, welded up, and filler used to reshape it fully. it's not on a body line, which makes it pretty easy. Again, if it's steel.
If the intrusion beam is hit, it's done and needs to be replaced. you can't repair intrusion beams (structural cross beam across the inside of the door). Depending on your insurance and the shop, you can push to get that replaced. Here's what will happen if you repair it. Paint blended into the fender, bumper dropped, headlight removed, door taken apart, welded, fixed, painted and blended within the door. If you replace it, all the above plus they will have to blend the paint into the rear door, in which they'll take the rear door apart to do that, sacrificing factory paint. Both have their pro's and cons. I would prefer replacing the door. EDIT: Have them check the back side of the trim panel, while the bullet may not have gone through, it could have damaged the back side of your trim panel on it's way in, or bounced around. Source: I see this all the time in MD |
9
TonyB5840.50 xander_g1018.00 alex23642915.50 chris7197375.50 Murf the Surf19216.00 tracer bullet2508.00 DrFerry6731.50 StradaRedlands4997.00 zero2sixtyZ952.50 |
01-08-2024, 08:44 PM | #20 | |
Rep 3,958
G35POPPEDMYCHERRY4998.50 DrFerry6731.50 |
01-08-2024, 10:59 PM | #21 |
Rep 832
Time to move OP
Two is One and One is None
01-09-2024, 08:09 AM | #22 |
Rep 55
Drives: 2010 Z4
Damn, Bruh...you live in Oakland Park??
Tags |
bmw m340i, bullet, bullet impact, collision repair, m340i, repair |
